586,102 active members*
2,620 visitors online*
    Dec 2008
    5
    Only get blue screen
    hi When I start up my A2100 milling machine it only gets as far as BLUE SCREEN. More help required please. many thanks gabby
    Dec 2007
    159
    Sorry my friend your going to need a hard drive.
    Aug 2008
    97
    while the first reply you recieved is often correct there are other things i have seen cause this.1 a stuck key on the touch screen or key board. 2 and quite common is you get a failure in the windows side of the control. when this happens you can ghost the drive and restore the system data with a windows data set that is not corrupt and you can often fix these. i would never put a hard drive in one of these as they do go our quite often. rather buy a adapter to install flash memory card such as you probably use in you pcmcia card adapter. there are some tricks to partitioning the drive correctly and use must use windows nt if that is what is on the machine. modern ghost software often tries to rewrite data into current methods and the machine will not work. If done properly you often can start right up if not you will have to install your purchase options prior to running. Every cincinati that i have has flash memory rather than hard drive which is 12-15 lathes and mills.
    Oct 2009
    34
    Gabby
    Can you send me the serial number of the control and the machine?
    Do you have in the documentation of your machine the test book that Cincinnati include in their machines?
    Please try it:
    turn on your machine.
    In your keyboard push the letter delete many times.
    let me know what happend?
    CNCVEN
  1. Mach3 Mill Blue Screen of Death.
    By Dougal in forum Mach Mill
    Last Post: 09-28-2009, 01:06 AM
  2. Homemade Screen Printer/Silk Screen
    By Sbthomas13 in forum Machine Created Art
    Last Post: 02-14-2009, 01:35 AM
  3. IH Blue Formula
    By IHCNC in forum Charter Oak Automation Support Forum
    Last Post: 02-18-2008, 11:28 PM
  4. blue screen of death
    By norvil1 in forum Machines running Mach Software
    Last Post: 10-15-2006, 09:24 PM
  5. jewelers blue carving wax
    By copper3416 in forum Material Machining Solutions
    Last Post: 04-17-2006, 05:49 PM
