586,105 active members*
2,955 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > G74 command format for Melda 520L control
Results 1 to 7 of 7
    Feb 2008
    86
    Here's a real newbie question. How do I program a G74 peck drilling cycle on a Mitsubishi Melda 520L control mounted on a Daewoo 8s lathe? Apparently its not like the Fadal std. A simple programming example would be a huge help. Thanks. Dave
    2932
    I don't have a 520L programming manual, but this is from the 700/70 Series:
    Let's say you want to drill 2" deep with 1/2" pecks and a 0.02 chip-break.
    G00 X0 Z0.1
    G74 R0.02
    G74 Z-2.0 Q0.5 F0.012
    Feb 2008
    86
    Thanks. I'll try that out tomorrow. Its funny with all the little quirks I've worked through on this machine I gave up trying to figure out this cycle.
    Jun 2009
    28
    Quote Originally Posted by dcoupar View Post
    G00 X0 Z0.1
    G74 R0.02
    Will this also work on a Fanuc style control?
    2932
    Quote Originally Posted by Jawbreaker38 View Post
    I believe it will if you change the Q0.5 to Q5000
    Jun 2009
    28
    Excellent! Thank you.
    Feb 2008
    86
    Here's where it gets real interesting.......
    It turns out that the inherent controller programs for G74, 75 ect on my machines don't match whats in the meau instruction manual. To make things more interesting, when I output the programs that on the control, I see a different program on the machine screen than whats output. :O
    The guys at Daewoo and Mitsubishi have been very helpful and I'm waiting here back from Mitsubishi on how to rectify this. They seemed a bit boggled by the episode but one of the Daewoo tech guys seemed to remember something like this happening before. Never a dull moment in my shop....
    Thanks for the help guys.
  1. Format for "Send Command to Card"
    By squarewave in forum CamSoft Products
    Last Post: 05-26-2009, 01:55 AM
  2. Blown a meldas 520l with to much voltage
    By SQT18MS in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-22-2008, 10:35 PM
  3. Melda M60-system Password
    By CHANDRU in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-17-2007, 02:03 PM
  4. command line control
    By wjfiles in forum Mechanical Calculations/Engineering Design
    Last Post: 06-04-2006, 01:11 PM
  5. Sending a Command to Control
    By daking in forum NCPlot G-Code editor / backplotter
    Last Post: 05-02-2006, 10:04 PM
