Hi All,
I used to work with CNC 15years ago, till recently when I got involded in a factory stock clean up...
purpose is first to get a single controller+ servo working again and w'll see from there, idea is , like many here , to make my own 3axis build. not only the build build also the programming intrigues me ..
so hereby , my first question
the controller :
Yaskawa SGDA-04VS Servopack , which think is a speed controller and not a torque controller , for 'playing' around more than enough .
the servo...saddly enough someone manager to wipe the details partially.
my questions:
-can I drive the SGDA straight from serial port (RS232)or do I need some middleware?
does anybody have a idea about the servo wiring?
- the thick orange (labelled : KEB 00.S4.019-0010) one has 3 thick leads(the 3 phases) and 2x2 thinner wires coming out.
- the other orange (labelled : KEB 00.S4.109-010) wire is most likely the encoder and has 5 black wires with no marking.
I tried the search function first but did not find the info I needed,
all help/feedback welcome
for easy of use I temporarly added the images to my other website
small image
http://www.roofthooft.com/cnc/small-100_2263.jpg
large image
http://www.roofthooft.com/cnc/100_2263.JPG
Best regards,
Luc
