Originally Posted by
Superman
What happens if the program is interupted, and you want to change tools ?
This is the MTB system setting area, you are fooling with the actual running of a machine function, the toolchange arm will not align with the drive keys and will eventually destroy the toolchanger altogether, maybe even the spindle tool clamp function as well
Yes, you can do it, but look at all senarios, who can do what ? can it be an accident waiting to happen, who's a$$ gets the kick if it did occur ? ( the operator is not to be held responsible for someone else's stupidity ). This is not a cheap fix and not covered under any form of warranty
I would find another method of adjusting the orientation, possibly assigning it to a M or G code that allows the M6 ( toolchange ) to cancel this orientation shift ( I don't know your machine, so I cannot help )
