586,069 active members*
3,619 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > VH 65 A axis rotation
Results 1 to 6 of 6
    Oct 2008
    24
    I had posted previously on this.
    The jumper socket is supposed to have 12-5 jumped along with another (I don't have a manual in front of me). I've been trying to get the 4th working (finally did) but I'm not sure about the jumper. I re-installed the 12-5. It had been cut somewhere in it's life, before me. The axis rotated +A CW, I clipped the jumper again. No change. I swapped the motor leads at the amp, (it didn't like that). What else can I do to change the direction of rotation?
    Tim
    Jul 2009
    317
    TRY 7-10
    Jan 2004
    3154
    Is this how and where you have it mounted?
    www.integratedmechanical.ca
    900
    The jumper at J4 of pins 5 to 12 is for the direction of the motor along with the proper connection combination of the motor and tach wires.
    Neal
    Oct 2008
    24
    I do have the axis mounted as shown in the picture.
    I did try swapping the motor leads (at the amp) so I will try swapping the tach leads.
    Tim
    Sep 2009
    15
    Re: VH 65 A axis rotation
    What would the jumpers be set to if the chuck face was horizontal (can it be?) instead of vertical on a VH65? Say the motor is positioned in the same direction as the pic, above.
  1. Replies: 16
    Last Post: 09-11-2017, 10:31 PM
  2. A axis rotation ????
    By dunnitagain in forum Fadal
    Last Post: 07-29-2011, 01:50 AM
  3. Rotation along the y axis?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 07-09-2010, 05:27 PM
  4. B axis rotation
    By fitzpatrick2362 in forum MetalWork Discussion
    Last Post: 10-12-2009, 12:06 PM
  5. X axis to A rotation
    By quemast in forum G-Code Programing
    Last Post: 06-18-2006, 02:36 AM
