586,060 active members*
4,107 visitors online*
    Nov 2009
    G-code programming library in python
    So now that I understand that most of the real skull sweat of cnc machining seems to be in g-code I was surprised at how little there was out there in terms of higher level programming tools for g-code, unless I missed something major.
    In any event I kludged together a python module for creating g-code and added a fairly basic gui to it (no backplot). It's called pygcode and it's on sourceforge. While this is a bit late to ask I thought I'd enquire if a) there's some tool out there I'm missing I should be using instead of continuing to develop this, and b) if anyone had reasonable suggestions as to what makes sense to add. For now it's really only set up for g-code for emc using my sherline mill, but I made it fairly extendable. In any event, some useful feedback would be appreciated.
    --Mark
    Feb 2006
    338
    I'll have to look what you have over, but it sounds like your shooting for something similar to "shop floor programming" like what machine tool builders sometimes put on the controls.
    Or to some extent a CAM package.
    You build the part by answering basic questions. Material size and location. Pocket type, size, depth, location. Hole type, size, depth, location. ect
    Not to discourage you from continuing, but if your looking to create better tools, you might look at helping with http://gcam.js.cx/index.php/Main_Page instead.
    If you just want some free tools perhaps, http://www.gsimple.eu/download.html or http://www.mecsoft.com/freemill.shtml
  1. Programming with Focas library
    By SRogers in forum Visual Basic
    Last Post: 08-15-2022, 06:22 PM
  2. Help! need someone to help w/ some mach 3 g code programming
    By sconklin in forum Mach Wizards, Macros, & Addons
    Last Post: 07-01-2010, 01:53 AM
  3. just another python gcode thing
    By cyclestart in forum LinuxCNC (formerly EMC2)
    Last Post: 02-18-2008, 03:54 PM
  4. simple python g-code generators
    By Dan Falck in forum OpenSource Software
    Last Post: 11-26-2007, 11:37 PM
