CAM SOFT PRO, Galil 1840 Rev C, 2 axis gantry with 3rd axis slaved to 1st. Last week it was as smoth as silk. Today the goofy ghost came, and the machine pauses for about 1/2 second at the end of every G1 or G2 line of code, using an oxy fuel torch it leaves witness marks that have to be welded up and sanded out, because of the jerky start stop motion. Called CAM SOFT and they suggested changing smoothing to -50 or servo tuning. any # more than 5 above or below exhisting PID will cause the machine to chattter and jerk or go slow and then jump to position, so the tuning is about as close to middle of road as possible. smoothing at any number had no effect. tollerance on general settings page from .001 to.01 had no effect on the opperation. the only thing differrent is a new touch screen control panel and an Opto 22 board with 4 new M codes to operate solenoids.
This will make you want to plow in a circle.
The Farmer
