Originally Posted by
zax15uk
Use the select tool (arrow) and click on a vector, then you'll see a drop down for changing scan to cut.
I find Newlydraw perfectly acceptable (as a driver), and for engraving and basic cutting out it is more than adequate. I bring artwork in from my CAD/CAM software as DXF which it does an excellent job of importing, set the cut order and layers if needed and send the job to the machine. On the small engraving machine it is true the power needs to be adjusted on the machine but the others have software control.
The only issue I have is on the non-USB version, where the speed can not be reduced enough and without PWM in vector cutting it is limited in thickness or requires 2-passes. That is why I am interested in the fullspeceng solution, although not until it is USB and has good raster capability.
Zax.
