586,042 active members*
3,874 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Multiple Work Offsets
Results 1 to 6 of 6
    Jan 2007
    129
    Hey Gang,
    Just finishing up my last year in school and learning tons. Asked my instructor how to post multiple work offsets and he didn't really know.
    anywho,....... what I want is to build the part and have it posted for 3 vice (54 55 56) Currently I copy all the needed operations into a new tool path group and select planes, then 1 (for 55) 2 or 3 etc etc for all three offsets.
    This produces the correct posting but each part is completed one at a time. No good. It needs to post each opp once for each offset (ie: spot drill at 54 55 then 56 then drill 54 55 56 etc etc) eliminating excessive tool changes.
    To copy each operation three times for each off set and change the planes individually seems cumbersome and ripe for an error.
    Gibbs cam has an input field for "Number of vice" which in turn posts offsets for each opp for each vice...........
    Any help out there? I'd be greatly indebted to you all AND a rock star in class!! :rainfro:
    Owen
    9 1/2
    B.C.I.T. Machinist CNC
    Aug 2009
    106
    Owen,
    "This produces the correct posting but each part is completed one at a time. No good. It needs to post each opp once for each offset (ie: spot drill at 54 55 then 56 then drill 54 55 56 etc etc) eliminating excessive tool changes."
    Take a look at Transform Toolpath.
    On the first page on the bottom left of the Transform Toolpath dialog you will see where you can choose:
    Group NCI Output By:
    1. Operation Order
    2. Operation Type
    From what you described that you want to do you need to use: Operation Type.
    From The Mastercam On-Line Help:
    "Operation type-> Groups the transformed operations by the operation type. For example, if you selected a pocket and a contour operation, all transformations of the pocket operation would be executed together, as would all transformations of the contour operation (pocket, pocket, contour, contour, etc.)"
    "To copy each operation three times for each off set and change the planes individually seems cumbersome and ripe for an error."
    I agree that it's "cumbersome and ripe for an error". It's also not associative.
    Take a look at the first page of the Transform Toolpath dialog box. On the bottom right you will see:
    Work Offset Numbering
    0 = G54
    1 = G55
    2 = G56
    etc.
    Jan 2007
    129
    Thank you so much!
    I had to experiment with the options contained within the Transform tool path dialogue but finially got it sorted out.
    Monday I'll put this to the class, I'm assuming my instructor either didn't understand what I was asking or wanted me to dig a bit on my own. Well I hope asking here would be considered "digging"
    Peace.
    owen
    :cheers:
    9 1/2
    Mar 2005
    988
    Also,...
    if you have a post that supports sub programming for multiples, you can have a single file/single part program and output for as many vices as you need.
    Just another option....
    It's just a part..... cutter still goes round and round....
    Jan 2007
    129
    Thanks physco but, I don't believe this post does or if it does I don't know how or where to sellect that option.
    The Gibbs post we use has that option. I take a look again and see if I've over looked some thing.
    9 1/2
    Aug 2009
    106
    Quote Originally Posted by 9 1/2 View Post
    Thank you so much!
    Peace.
    owen
    :cheers:
    You're quite welcome.
    One important thing I forgot to mention is on the first page and listed as:
    Method:
    Toolplane
    Coordinate
    Make sure you understand why you would choose Toolplane vs. Coordinate.
    Finally, a few pieces of advice if I may based on my 2 years of real world experience using Transform toolpath to make parts with.
    1. Experiment with all the options in Transform Toolpath to see what they do.
    2. Tranform Toolpath is an area of Mastercam that I feel is often very buggy especially Transform Mirror where my advise to you is to *always* 100 precent check what Transform Mirror gives you as it often does some strange things on its own like reversing chains where it shouldn't.
    I have found that often in Mastercam when I don't get what I know I should be getting I close Mastercam and restart it. It's truly amazing to me how many problems this solves. This applies to all versions of Mastercam I've used... X2, X2MR2 SP1, X3, X3MU1, X4.
  1. multiple work offsets in MCX
    By bob1112 in forum Mastercam
    Last Post: 10-01-2008, 02:17 PM
  2. Multiple Work Offsets X3
    By timmydabull in forum Mastercam
    Last Post: 08-28-2008, 06:54 PM
  3. Multiple Work Offsets
    By PinMan in forum BobCad-Cam
    Last Post: 06-06-2008, 10:41 PM
  4. Multiple work offsets in mcx2?
    By Bullnerd in forum Mastercam
    Last Post: 03-25-2007, 05:14 PM
  5. multiple work offsets
    By rbest27 in forum Surfcam
    Last Post: 01-25-2007, 10:02 AM
