586,312 active members*
4,892 visitors online*
Results 1 to 19 of 19
    Feb 2006
    28
    helical interpolation 15m
    a couple of years back i had a problem getting my machine (with fanuc 16i) to cut arcs while feeding in z at the same time. The problem was solved by changing the parameter #9930 from 01000111 to 01001111.
    Now, different machine same problem...
    I'm using a fanuc 15m controller, would anyone have an idea which parameter i would have to change? Here is the same example as before:
    T1
    M06 ( 2" MITSUBISHI)
    G00 G90 G54 X0. Y0. S700 M03
    G43 H1 Z2. M08
    Z.1
    G01 Z0. F45.
    G03 Y.4685 I0. J.2343
    Y-.4685 Z-.025 I0. J-.4685 (This is where I get the alarm)
    Y.4685 Z-.05 I0. J.4685
    Y-.4685 Z-.075 I0. J-.4685
    Y.4685 Z-.1 I0. J.4685
    Y-.4685 Z-.125 I0. J-.4685
    The alarm I am getting is; 021 Illegal Plane Axis Commanded
    Thanks!
    Goran P.
    Feb 2006
    1792
    Helical interpolation might be an option. Somebody may PM you the option parameter.
    Your program is for G17.
    Jun 2008
    1511
    PM sent.
    Stevo
    Feb 2006
    28
    thanks, i'll give it a try.
    Aug 2009
    I have this same problem with a fanuc 15m.Any help on the parameter for this would be greatly appreciated. Thanks
    Jun 2012
    I also just ran into the same issue on fanuc 15m. Any help with the option parameter is greatly appreciated.
    Jun 2012
    Dec 2009
    955
    Quote Originally Posted by Trebit View Post
    pm sent to you !
    Jan 2009
    245
    You are defaulted by g17 which is x y plane. Xz is g18 and zy is g19.
    Jun 2012
    Thanks for the PM.
    Everything is working good now.
    Oct 2013
    I have this same problem with a fanuc 15m. Any help on the parameter for this would be greatly appreciated. Thanks
    Oct 2013
    Mar 2005
    816
    Never have tried in depth the helical interpolation except to make a part with a 1.25" hole in the wide center web of a z shape extrusion.
    I too have a 15M.
    I would like to try threadmilling with helical interpolation with a inserted tool. Vargus/Carmex.
    Feb 2011
    100
    I do a lot of thread milling.Once you use it you cant go back.
    Typical program.
    N1 M6 T2 (16TPI THREAD MILL)
    N2 M03 S4000
    N3 M8
    N4 G90
    N5 G54
    N6 G43 X0.629 Y1.1652 Z1.0 F100 H2
    N7 M8
    N8 G1 X0.629 Y1.1652 Z1.00 F50
    N9 G1 Z0.100 F20
    N10 G1 Z0.0001
    N11 G1 Z-0.7578
    N12 G1 X0.7901 Y1.4605 F20
    N13 G3 X0.629 Y1.6127 Z-0.75 R0.2863 F6
    N14 G3 X0.629 Y1.6127 Z-0.6875 I0 J-0.4475
    N15 G3 X0.4679 Y1.4605 Z-0.625 R0.2863 F6
    N16 G1 X0.629 Y1.1652 F20
    N17 G0 Z2.00
    N18 M2
    Mar 2005
    816
    Neat, I'll have to try something like that. 8tpi and 16tpi and 20tpi I do frequently.
    I do have the tooling
    Sep 2008
    100
    Re: helical interpolation 15m
    Quote Originally Posted by D9ueh View Post
    Me too please
    Jan 2019
    Anyone have the parameter info for changing this? Running into the same issue....
    Apr 2009
    1379
    send me an pm.
    Jan 2020
    I also have the same problem if you could please pm me the parameter to change it would be massively appreciated. Thanks again
  1. helical interpolation
    By amarti06 in forum Fanuc
    Last Post: 01-05-2018, 10:58 AM
  2. Helical Interpolation in V14.2 Pro
    By squarewave in forum CamSoft Products
    Last Post: 07-27-2013, 04:11 AM
  3. Helical Interpolation
    By eliot15 in forum GibbsCAM
    Last Post: 09-18-2011, 03:40 PM
  4. helical interpolation
    By Montabelli in forum Mastercam
    Last Post: 04-11-2010, 03:34 AM
  5. MV 35/40 Helical Interpolation
    By Millem in forum Uncategorised MetalWorking Machines
    Last Post: 12-12-2007, 03:54 PM
