586,119 active members*
3,676 visitors online*
Results 1 to 3 of 3
    Dec 2005
    63
    Question tl-2 home settings
    can anyone explain how to change the home position on a tl-2 series lathe, it has a 4 position tool turret I would like to use the tail stock but the tool change location will slam into it if I try to move it in the z- direction at all.
    RMILES
    Jul 2005
    181
    Why not changing tools elsewhere of the origin?
    Move with Rapid to convenient position
    I do not have turret and must change tools by hand. I move the toolpost away by x125 and z125 whenever cycle asks for tool change. That ensures I do not bump the tools against the work.
    I simply got that by going to IPS and selecting OD Turn, and then select Rapid and there you define where you would like to move your toolpost from G54. Hit MDI (on 5% rapid) and check where you are going. Then adjust your position until you are happy. Simply append that rapid move into your machining program as easy as follows:
    Hit F4 to add to program, select "write to program" select the program, position cursor where you would like to paste the rapid routine, hit write/enter twice and there you are it is inserted.
    Then check the program with run (rapid at 5% and hand on Feed Hold to stop if you see any problems!)
    Hope that helps.
    This my 3rd day with my Haas and I have never operated a CNC before and find this really interesting.
    But I notice a member here named Geoff and I am sure if he has the time he could really help you. Seems to me he knows the TL1 backwards.
  1. Part Home vs. Machine Home
    By Mihelich in forum G-Code Programing
    Last Post: 06-07-2009, 07:56 PM
  2. Mach3 CV settings vs. G-100 Plugin CV settings
    By Bfarn in forum Machines running Mach Software
    Last Post: 12-17-2008, 05:45 PM
  3. Home again Home again Jiggety Jig. Well Not Just Yet!
    By Mr.Chips in forum DIY CNC Router Table Machines
    Last Post: 03-19-2008, 02:58 AM
  4. HOME LIMIT SETTINGS IN EMC2
    By Gads in forum LinuxCNC (formerly EMC2)
    Last Post: 02-14-2008, 12:50 AM
  5. Fadal work coords & home settings
    By Shizzlemah in forum Fadal
    Last Post: 11-09-2006, 02:57 AM
