Greetings all,
My name is Travis and I am new to the board and CNC in general. The company I work for has recently purchased a Roland MDX-540sa with Rotary a-axis, and we are having a bit of trouble with Aluminum and some other materials and was hoping that someone here might be able to set us straight.
simply put, it seems that everything I put in the machine runs for a time and then I run into some sort of overload fault, whether x, y or z. I have seen this machine tear into aluminum like a champ with no problems, and other times it stubs it's toe and starts to cry. I don't get it.
It feels like if where to try and run a job like this I could not.
[ame="http://www.youtube.com/watch?v=ejLVRmp5mck"]YouTube- Roland MDX-540 milling aluminium keypad[/ame]
also the roland software doesn't have very good plunge control, I can't seem to find a way to change plunge vs feed. every fault as occured right after a plunge.
sorry for the long winded and scattered thought post.
hope someone out there knows my pain.
Thank you,
-Travis
