586,108 active members*
3,071 visitors online*
    Oct 2007
    307
    Dead soft copper?
    Is this Alloy C110? Is dead soft just a "street" term? Looking to make some engine exhaust gaskets.
    Oct 2009
    22
    Dead soft is not a "street term".It is the softest level of the annealing process for copper.
    Oct 2007
    307
    ok. Is it the same as C110?
    Oct 2009
    22
    C110 can be dead soft.
    Jan 2006
    23
    You can anneal it yourself with a propane torch or weed burner. You can even quench it with water after heating. That won't make it brittle like carbon steel. I've done this to work copper sheets that end up work hardening after hammer forming. I will heat up the area again and work it until I get the shape I need.
    J.
  1. Fanuc 0 dead screen ... dead control?
    By Noss Machine in forum Fanuc
    Last Post: 01-24-2009, 04:03 PM
  2. Replies: 2
    Last Post: 08-30-2006, 11:08 AM
  3. I have the driver, but, i need an other soft
    By NCN in forum DIY CNC Router Table Machines
    Last Post: 02-02-2006, 09:22 PM
  4. Need a simalation soft
    By hanho in forum Uncategorised CAM Discussion
    Last Post: 10-17-2004, 03:47 AM
