586,104 active members*
3,403 visitors online*
Results 1 to 7 of 7
    Mar 2009
    291
    saveing prints
    How do i save a bobcad v23 print so i can e-mail it without the cad data.
    I want to e-mail just the drawing like a .jpg or somthing.
    Feb 2009
    68
    Can you scan it on a copier that hooked up to your computer and save as a different file extension.
    David.
    Mar 2006
    35
    If you push and hold the PrtScn button on your key board for 1 or 2 sec, it will save a jpg image of your part that you have open in the BobCAD/CAM program file image folder by default. You can change the Image file directory by going to preferences (in the bob cad drop down menu)/ setting default /directories / images.
    Hope this helps.
    Mar 2009
    291
    Images
    It doesnt seem to be saveing anythine in images.Is there a computer setting that i need to change?if i do ctrl and print screen it does a screen shot of everything including all the bobcad stuff like the cam tree and tool bars.
    Apr 2006
    187
    Mar 2005
    368
    Quote Originally Posted by 1234567 View Post
    As mentioned, if you use Ctrl+Prtscrn, you're just copying image to your clipboard which you paste into a graphics prog and edit. (as I did with this image)
    To save your Bobcad screen image, set your image directory in Preferences and press prtscrn only. You may hear the hard drive as it records the file.
    On laptops, you may need to press a function key to activate the prtscrn.
    Mar 2009
    291
    prints
    ok got it thanks everybody
  1. Need to Convert Prints to Models
    By charger19690 in forum Employment Opportunity
    Last Post: 09-12-2008, 10:35 PM
  2. z axis plans/prints
    By rzbkrain in forum Open Source CNC Machine Designs
    Last Post: 08-04-2008, 11:58 AM
  3. Parpas/Incon Prints
    By amts in forum Community Club House
    Last Post: 06-30-2008, 10:34 PM
  4. Help finding prints please!!!!
    Last Post: 06-30-2008, 10:26 PM
  5. Mastercam X2 File saveing
    By Rally in forum Mastercam
    Last Post: 01-14-2008, 09:10 PM
