586,121 active members*
3,637 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco Yaskawa axis drive problems
    Nov 2009
    16
    Hi all
    I'm having more trouble with my new BMC 40 with Ultimax II. It has yaskawa servos and drives. The drives are CACR SRCA 20BBB and the motors are Usafed 20FB 2T's.
    The x axis jogs fine.
    The Y axis gives a "motion error detected" (I think that was the wording) when I try to move it, the drive card shows no error message.
    The z axis drive card shows a fault 1 but only after I press the z jog button. I looked this up here (page 3):
    http://www.acsindustrial.com/tech-do...ack-repair.pdf
    which states its an over current error.
    Before the machine was moved all was running so transporting has disturbed something. All plugs on all 3 axis motors were disconnected during moving as a lot of dis-assembly was required, I've checked them all again though to no avail.
    Any suggestions on causes and remedies?
    While I'm on the subject of these drive cards my longer term plan is to retrofit with EMC or centroid and add my Tsudakoma TNRC 301 4th/5th axis onto the machine. Are these drive cards reliable/up to the job or should I be updating them along with the control? I want the machine to be full 5 axis and fast for some patternmaking jobs.They seem to be expensive secondhand so I'm wondering about just replacing with modern technology.
    Many thanks
    Phil
    Jan 2007
    203
    If you have the metal Cable conduit check the wires inside that first.
    A while back I had all kinds of weird errors because of wires that where shortening to ground.
    All comments made are my opinion!
    Apr 2010
    I think it would be useful for you to contact 3E Services They do quoting and info over the phone and they can let you know what to do. They are honest people, not just out to get your money.
  1. Yasnac/Yaskawa PC NC Problems
    By iaknown in forum DNC Problems and Solutions
    Last Post: 12-30-2010, 10:29 PM
  2. Yaskawa servo drive in SL1
    By jkoper in forum Mori Seiki lathes
    Last Post: 08-10-2009, 03:21 PM
  3. Hurco/Yaskawa Issue
    By kwmkoester in forum HURCO
    Last Post: 05-11-2009, 02:09 AM
  4. hurco km-1 Z axis drive ?
    By D.D.Machine in forum HURCO
    Last Post: 01-11-2007, 02:19 AM
  5. Yaskawa AC Spindle Drive problems...blown?
    By nlh in forum Servo Motors / Drives
    Last Post: 08-04-2006, 01:19 PM
