586,103 active members*
3,405 visitors online*
Page 2 of 4 1234
Results 21 to 40 of 66
  1. #21
    Nov 2007
    197
    amazing stuff. was a little hard to visualize everything before, but now its all clear
    whats the next step?
  2. #22
    Nov 2005
    152
    Quote Originally Posted by multiplex View Post
    I am going to build the backgauge next once I get my ball screws from A4L.
  3. #23
    May 2007
    119
    Nice job you have going there !! What are you going to use for ram leveling ?
  4. #24
    Nov 2005
    152
    Quote Originally Posted by kevin swan View Post
    What do you mean by ram leveling?
  5. #25
    May 2007
    119
    left side vs right side during the stroke
  6. #26
    Nov 2005
    152
    Look closer at the pics. There are 35mm Hiwin linear rails guiding the ram so it will always stay parallel.
  7. #27
    May 2007
    119
    ok sorry i missed that thank-you
  8. #28
    Nov 2005
    152
    Today I got the backgage started. I machined up the ball screws and made the end supports. I also started machining up the frame for the backgauge.
  9. #29
    Oct 2006
    669
    Want to follow this, make sure I don't miss anything!
  10. #30
    Nov 2005
    152
    Today I got the manifold all done and also the Y block.
  11. #31
    Nov 2005
    152
    I made some spacers to hold the beams parallel. Then started to tack the cross braces into place. I also cut out all the parts for the hydraulic tank on the plas, then welded the tank all up.
  12. #32
    May 2007
    119
    looking good nice job
  13. #33
    Nov 2005
    152
    Today I mounted the tank, made the motor and pump mount and also mounted the manifold.
  14. #34
    Feb 2010
    All I can say is wow!! Keep posting, the work is outstanding and it's fun to see something of this scale come together! What is the max thickness you'll be able to bend?
  15. #35
    Dec 2009
    122
    I am impressed. I've been following since you started this thread.
    Some of us (including me) wish we had your talent.
  16. #36
    Nov 2005
    152
    Quote Originally Posted by dirtnap View Post
    48" of 3/16" mild steel or about 40" of 1/4" mild steel. 3/16" is about 12 tons per foot of bend with a 1.5" lower die and 1/4" is 15 tons per foot with a 2" wide lower die.
  17. #37
    Nov 2005
    152
    Yesterday I got the tank all pressure tested and finished, the backgauge all done and finished all the plumbing. I still need to finish making some support brackets for the hard lines.
  18. #38
    Nov 2005
    152
    Today I got the electronics started. I mounted the control box, Wired the power supplies and the motor starter. I also cut out a front plate for a small fan and a db25 connector for the MPG. I also cut out a rear plate for the motor power wires, encoders, limits/homes switches and for the valve.
  19. #39
    Nov 2006
    12
    your project looks awesome! ive been kicking around the idea of making something similar. one question for you. how did you make sure your linear rails are parallel? i can understand them being correct looking at the machine from the front being that all that stuff was milled. but what about looking at it from the side? maybe im missing something but didnt notice anything that would keep the sides from pivoting independent of each other in a sense making the rails not parallel.
  20. #40
    Jan 2007
    525
    bigtoy - what's with the shallow-depth of green liquid in the plasma table? I'm used to seeing a water trap which is quite a few feet deep; yours looks to be a few inches...
    Tormach PCNC 1100, SprutCAM, Alibre CAD
Page 2 of 4 1234
  1. Yawei pressbrake type QC12Y hydraulic diagram
    By zavateandu in forum Uncategorised MetalWorking Machines
    Last Post: 08-21-2012, 01:14 PM
  2. LVD Pressbrake?
    By rszemeti in forum Uncategorised MetalWorking Machines
    Last Post: 07-15-2012, 10:57 AM
  3. delem da 65 pressbrake controller
    By gerry1969 in forum Uncategorised MetalWorking Machines
    Last Post: 03-15-2012, 05:00 PM
  4. Suggest me the best Pressbrake machine
    By gvk1985 in forum Want To Buy...Need help!
    Last Post: 03-07-2011, 03:38 AM
