586,119 active members*
3,648 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > spindle orient when tapping
    Jun 2006
    247
    I need it to stop
    can I turn off the spindle orient before each hole in order to save cycle time?
    the machines are OSP-100m and -700m
    the tapping code is G284
    this is all new to me so thanks for any help at all
    Kenny
    Jun 2005
    142
    G284 is rigid tapping, right?
    Try a floating tap holder and G84.
    Dec 2008
    3109
    The M3 is not required to actually start the spindle
    it can safely be deleted
    The G84 and G284 forces the spindle CW when the tool goes to the R-plane when starting the cycle and stops the spindle at when it returns to the R-plane before going to the next hole.
    Prove off the cycle away from the part, for your own peace of mind
  1. spindle orient
    By nitemare in forum Daewoo/Doosan
    Last Post: 03-14-2013, 05:30 PM
  2. spindle orient problem
    By kokai in forum Milltronics
    Last Post: 05-12-2009, 02:46 PM
  3. Help with spindle orient
    By SIERRAMACHINE in forum Fadal
    Last Post: 03-10-2009, 09:36 PM
  4. M19 Spindle Orient
    By ragman in forum Fanuc
    Last Post: 04-01-2008, 11:16 AM
  5. Hurco MD1 spindle orient
    By caleb505 in forum HURCO
    Last Post: 11-25-2007, 02:14 AM
