586,119 active members*
3,518 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Drill cycle post-processor for a Charly4U
    Nov 2009
    Hi in my lab we have a small 3-axis cnc machine a charly4u
    http://www.charlyrobot.com/2-Web_sit...harly4U-GB.htm
    The only problem is that te machine does not support any of the G-code for drilling hole (for example g-81 and g-80)
    For the last couple of days I've been working on a way to circumvent the problem, but it does not work... EdgeCam always generate a canned drilling cycle and I dont know what to do.
    Thanks in advance.
    M.
    Jun 2008
    125
    Longhand drilling
    Hi M,
    There are two easy ways of getting longhand code for drilling.
    First one is on the hole cycle itself -see attached image. There is a dropdown box which lets you chose longhand or not.
    Secondly - on the post processor (CGD file which opens with Code Wizard) if you look under Nc Styles,G-codes and Modality, and then under Hole cycles you will find a check box that says 'drill cycles always longhand'.
    They should both do the same thing.
    Good luck!
    Mark
  1. Peck Drill Cycle G83
    By Sam A in forum G-Code Programing
    Last Post: 02-20-2016, 06:30 PM
  2. need drill cycle to post every point location.
    By kesparate in forum Post Processors for MC
    Last Post: 03-11-2009, 04:40 PM
  3. Peck Drill cycle generated by post??
    By nelZ in forum BobCad-Cam
    Last Post: 12-12-2008, 05:09 AM
  4. Fanuc G75 Grooving Cycle post processor
    By rk176 in forum FeatureCAM CAD/CAM
    Last Post: 11-07-2006, 02:00 PM
  5. canned drill cycle
    By nitrosnfr in forum MetalWork Discussion
    Last Post: 05-24-2006, 04:50 PM
