586,385 active members*
3,286 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Easy Cad. Z. Bavelloni v. 3.5
    Nov 2009
    6
    Exclamation Easy Cad. Z. Bavelloni v. 3.5
    im from Germany and work at a Bav. Alpa 320-4
    this software is very old and i cant export files to a format that could we readed with Autocad, etc.
    is it possible to convert the .DSG file to DXF or similar?
    someone have a easycad version @home? to test? if possible send it to [email protected]
    thx!
    Dec 2009
    Hi I Used to work for Bavelloni and am still a certified Technician for them. The only way to export a file into another format is that you have to type in manually .dxf at the end. That is the only way to do it. if you have the software that allows you to chose from the type of file you will want to select all files. so an example would be you want to save a file called Project.dsg you will continues like you always would when you save a file. You will then select all files (if you have that option) and then erase the letters "dsg" now in it's place you will type "dxf" so in the end before you save you should see the file name being "Project.dxf" Hope this helps you out.
    Nov 2009
    6
    thanks, it worked fine!
    Aug 2010
    12
    Quote Originally Posted by Kochleffel View Post
    https://www.dropbox.com/sh/r1iq0pr4cenmhz6/AABKiJU4lZmhqFm4oKVR0_wBa?dl=0
  1. EasyCad Z. Bavelloni
    By cbieger in forum Uncategorised CAM Discussion
    Last Post: 07-29-2021, 07:06 PM
  2. Bavelloni ALPA 450/4 N
    By stormi in forum Glass, Plastic and Stone
    Last Post: 11-09-2018, 03:39 PM
  3. Bavelloni Easy Laser
    By marktill in forum Glass, Plastic and Stone
    Last Post: 05-15-2013, 12:32 PM
  4. bavelloni
    Last Post: 09-25-2010, 03:52 PM
  5. Bavelloni Egar320T
    By JSandSO in forum Uncategorised CAM Discussion
    Last Post: 07-13-2005, 05:19 PM
