Originally Posted by
fizzissist
From that interview...
"Spectrum: The e-mail scandal obviously raises basic questions about the culture and ethics of science as it was being practiced at East Anglia, but tell me this: In what you've seen, is there any evidence that the temperature record was seriously distorted, or is there evidence of outright fraud?
JC: When it comes to the record of surface temperatures that Phil Jones led, I don't think it's going to change very much. More serious is the paleoclimate reconstruction from tree rings and so on. Here there was an attempt to give an impression of a time series that the underlying data did not support.
Spectrum: So the temperature record for the past few decades is fairly intact, but the record going back, say, a thousand years may now be open to dispute?
JC: That's right.
.....I have to disagree with Christy, as demonstrated by the NOAA/GISS manipulation of surface station records we're seeing. I'm afraid I don't understand how Christy would not be aware of these "adjustments", especially now.
The Orland and Marysville Stevenson screen records are as smoking as a gun can get if you want proof. If those records had not already been sequestered by Watts, nobody might have been the wiser....but...
The original raw data was downloaded and stored. Then, as if by a miracle, an adjustment was made that had no basis or justification that made earlier temperatures artificially cooler. Watts and others spotted the change and blew the whistle. The obvious result is that later temps will appear to have been increasing at a much higher rate. That kind of adjustment is now found to have been made at stations across the globe. That's what the furor is all about when it comes to surface temps, and why the entire premise of global warming MUST be re-examined.
On top of that, we went from 6000 temp stations to 1000 and went to a gridded format, where the grid cells were some 2400sq km and temps were averaged to adjacent cells if no station existed.
Wouldn't it be nice if you could do QC like that? You've made 1000 parts, done a 100% inspection, put the 30 parts aside that didn't meet spec, re-inspected the remaining 970 parts, declared Zero Defects, then added the 30 parts back in and shipped the order.
When the customer complains that there's bad parts, you tell him that you did a clever trick, and he's taking it all out of context.
