I have a similar model and Techtronix refer to Ch1 & Ch2 you should be able to see two channels at once without alternating, but in your case I would assume you just want to observe one channel? If so the probe should have the the ground wire coming off just below the probe end, which you will need to connect, also your problem may be because of the sync switch is not set to trigger on the channel you are using, and in that case the display will free-wheel and high frequencies will look like a blur.
Al
Albert E.
