586,080 active members*
3,771 visitors online*
    Oct 2009
    10
    Talking Cricut Hack A new Heart
    I wanted to learn more about CNC stuff and get into Mach and EMC, so I got a couple of dead Cricuts for parts (They're really cheap off Ebay now). I also got a good Cricut so I could compare results. I want more control than ProvoCraft allows and Sure Cuts Alot is a good stop gap for now, but I want more, hence Mach and the others that are more generic.
    At the Moment I'm trying to add a Toshiba TB6560AHQ driver to an Original Cricut. Once that works, I got a 12"x24" that I'll use. It of course uses the parallel port for interfaceing. I'm still looking at exactly how to hook up the 6 wire motor to 4 wire controller. It says it works with motors with up to 8 wires, but it's not obvious to me how. Am I losing some accuracy using less wires? Besides being a CNC newbie, I'm also electronics newbie when it comes to circut level stuff, so most goes way way over my head, but I want to start learning.
    I got to looking at the motherboards I took out and saw they use an ATmega128. Wow!! Just like the Arduino Mega I got to learn microprocessing for a motorcycle project. Now maybe instead of just blinking some LEDs, I can mess with interfacing it to a dead Cricut. A new heart so to speak. I've already traced which pins are used for motor control for each axis and which control the magnets for pressure on the blade. Plus maybe I can reuse the USB chips to make it a more modern interface. My newest PC has no parallel port. I have to learn USB control too! All that circut tracing was electronics lesson in itself. I've already starting looking for ATMega code for motor control. I'll probably use Mach3 for higher level stuff, even though Scal would be fine for me If I could find how it talks. Another thread in itself. IMO I think it keeps boundries simpler and it's affordable compared to others. I use Adobe products for design and such, so Scal or whatever is more like a printer driver from my point. I got lots of work ahead, unless someone has done and willing to offer guidance.
    Dec 2009
    Anymore process on this?
    Feb 2011
    Hi Bdanyeur, Did you ever sucessfully hack the cricut?
    Oct 2009
    10
    Circuit hacks
    Yes and no to hacking. I created a x and y axis using the toshiba card with Mach III easily. I don't know enough electronics to do the up down solenoid. So I did learn alot of cnc stuff from messing around, but I never got it to work completely that way. Plus the card cost lots more than dead Cricuts.
    What I really hoped was a reprogram of the atmel processor so I could reuse the existing processor. I had to sign some release for atmel in Norway in order to get software and dev center, but never got confirmation back.
    I got busy on other projects and hadn't gotten back.
    In the meantime someone else has sucessfly made great progress in replacing the Provo code with their own. It isn't 100% yet but most C programmers have a huge head start. I found it from links in a youTube video on Cricut hacks. So now I'm looking for an adobe illustrater HPGL driver. Cut out without having to use another program.
    Turns out Cricuts are somewhat compatible with several other cutters and plotters.
    This new atmega128 code opens up a lot of robotic controls being made from Cricut parts for a lot less than buying new controller parts. Cricuts are pretty tough. I've seen women cutting aluminum cans and chip board. That is if the Cricut makes it past a month. I have several almost new Cricuts I've acquired with doa boards. Like most electronics they have their share of new failures. After that they are tough.
    Bill
  1. Cricut Hack
    By asenna in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 10-03-2019, 06:54 PM
  2. Cricut, Xyron, cutter blades
    By nikolatesla20 in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 10-29-2009, 03:16 PM
  3. cricut stepper motors
    By David Flowers in forum Stepper Motors / Drives
    Last Post: 04-20-2009, 07:43 PM
  4. Hollow heart lamps
    By WayneC in forum Vacuum forming, Thermoforming etc
    Last Post: 03-30-2009, 05:04 AM
  5. Take Heart You questionable spellers
    By Al_The_Man in forum Community Club House
    Last Post: 11-16-2004, 04:32 AM
