586,195 active members*
4,055 visitors online*
Thread: TAIL STOCK
Results 1 to 6 of 6
    Dec 2007
    48
    TAIL STOCK
    IVE GOT THE TAIL STOCK MOVING IN AND OUT BUT I CANT GET THE WHOLE THING TO MOVE THIS IS ON A OSP5020L CADET DO I LOOSEN THE TWO HEX BOLTS ALL THE WAY OUT OR LOOSEN SOMETHING ELSE THANKS FOR ANY HELP.
    Feb 2009
    6028
    Two hex bolts on the side of the base. Loosen till they are free. Should be 1/2 turn.
    Feb 2009
    58
    I have a programmable tailstock and have no bolts to loosen on a crown L1420. Try to use the quill to push it.
    Jan 2008
    575
    Seriously turn caps lock off, I will not respond to another one of your posts if you don't, loosen the bolts, use a strap around the back of TS, connected to a bar holder or something on the turret and handle jog it forward, if you get an alarm something is wrong.
    Then repost NOT in caps.
    The beaten path, is exclusively for beaten men.
    Apr 2006
    822
    DOES NOT LISTEN TOO WELL DOES HE?!? hahaha
    Feb 2009
    11
    On my Okuma, loosen the tool bolts on the bottom. It has tow along feature on it, a little button on the front. Line up the turret with this, push the button in and it will lock in place, then just drag ot along with the hand wheel to where you want it, back it off a little and release the button
  1. TAIL STOCK OSP5020L CADET
    By bruiserba in forum Okuma
    Last Post: 11-23-2009, 01:50 PM
  2. Mori Seiki SL-00 Hydraulic Tail Stock
    By mrchang in forum Mori Seiki lathes
    Last Post: 02-20-2009, 03:38 PM
  3. Logan 400 to 6561 tail stock adapter
    By santiago lisboa in forum Uncategorised MetalWorking Machines
    Last Post: 11-25-2008, 06:30 PM
  4. Tail stock wont Advance
    By Jedi in forum MetalWork Discussion
    Last Post: 11-16-2006, 02:20 AM
  5. head stock and tail stock chucks
    By mocnc in forum DIY CNC Router Table Machines
    Last Post: 10-20-2004, 03:16 AM
