586,094 active members*
3,687 visitors online*
Results 1 to 9 of 9
    Nov 2009
    32
    PCI 1 port parallel card
    Heya
    I have got Proxxon CNC micro mill. My computer has no parallel port.. so I have bought a 25 pin parallel port PCI card. However when I enter the 4 digit Hex Decimal number found in device manager-ports(com+lpt) resources into port 1 location this does not seem to correspond to the parallel port output. Is it possible that this is the location for the PCI card. If so how do I find the true address of my parallel port
    Thanks Noyloj
    Jun 2007
    3757
    Run this file.
    This program will scan your computer and generate one or 2 files in c:\
    The smaller file lists the ports found, the larger one has the parallel port info near the end.
    Put the .exe file on your desktop and close other programs before you run it. (The dialog box may be hidden under some other window)
    Attached Files Attached Files
    Nov 2009
    32
    Thanks Neil
    Will download and give it a shot.
    Jolyon
    Nov 2009
    32
    Sorry
    Any idea what files will be called?
    Mar 2004
    1806
    it gives a popup withthe path and file name. Good little program!
    Art
    AKA Country Bubba (Older Than Dirt)
    Nov 2009
    32
    Heya Bubba
    Unfortunately program did not complete.. half way thru got pop up saying access denied.
    I'm running vista!
    Hmmm.
    Mar 2004
    1806
    Can't help you with that as I don't run Vista. It worked on my XP machine with not problems. I simply double clicked on the exe file and it extracted and ran.
    Art
    Jun 2007
    3757
    Question access denied.
    Quote Originally Posted by noyloj View Post
    Heya Bubba
    I'm running vista!
    Hmmm.
    The reason 'access denied' is because program could not write report file to the root of the C: drive.
    Probably needs some sort of compatibility mode in the shortcut.
    Jun 2007
    3757
    Name..
    noyloj
    Sorry
    These same name as the (dot).zip file with .exe extension.
    You have to extract it from the zip file.
    Some antivirus software will try to defeat it too, but (IMHO) is harmless.
    After further investigation this program runs:
    C:\Program Files\Common Files\Microsoft Shared\MSInfo32.exe
    and redirects the output to C:\SSportinfo.txt
    see screen shot below..
    You can run the program yourself and it should show you what you need.
    Command line options (captured by alt-prtsc). I ran it from dos prompt with /? option.
    Use the computers utilities to find out what you need.
    From the start button cut and paste the bold program line, and with any luck you will run the program.
  1. parallel port versus pci card system
    By js412000 in forum LinuxCNC (formerly EMC2)
    Last Post: 08-03-2009, 10:10 PM
  2. parallel port or parallel universe
    By bruno34 in forum Taig Mills / Lathes
    Last Post: 04-15-2009, 04:58 PM
  3. PCI Parallel Port Card
    By Adamj12b in forum Mach Software (ArtSoft software)
    Last Post: 12-23-2008, 04:03 AM
  4. Cheap parallel port card
    By fahque99 in forum Mach Software (ArtSoft software)
    Last Post: 11-24-2008, 02:07 AM
  5. pcmcia parallel port card ?
    By WsW-WYATT in forum DNC Problems and Solutions
    Last Post: 09-07-2005, 12:29 PM
