586,416 active members*
3,316 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Buying steppers soon need advise...
    Mar 2006
    233
    I have a g540 and I am about to buy steppers. I am up in the air about these two. Which should I get based on specs?
    These http://www.kelinginc.net/KL23H284-35-4B.pdf
    or these http://cncrouterparts.com/specs/NEMA23_Specs.pdf
    Also would this power supply be ok for the g540? Its the S-350-48 model.
    http://cncrouterparts.com/specs/ModelS-350W.JPG
    Quote Originally Posted by SatanKlawz View Post
    The specs are basically identical.
    Sep 2009
    11
    Wouldn't the KL23H2100-35-4B be a better choice for the G540? It has a lower inductance that is more in line with the G540 requirements as stated in the G540 manual.
    Mar 2008
    3655
    Hi SatanKlawz.
    NEITHER of those motors are best. They BOTH have high inductance for G540.
    The 387s are slightly better and less expensive than the CNC router parts motor. That motor DOES come wired with a 12 inch cable, but you have to buy the $16 extension to use it. Total cost= $68 each. If you can solder, get the $49 Keling 381s they are the VERY best G540 motor yet. The CNC router parts PSU is less expensive than Keling's and appears to be the same thing, so you COULD probably use that--although I'd bet Keling would match that price.
    http://cncrouterparts.com/product_in...products_id=41
    This is what I recommend:
    http://crevicereamer.com/Page_31.html
    CR.
  1. Cons on buying servos 2-3x my requirements. I need advise
    By rodjava in forum DIY CNC Router Table Machines
    Last Post: 02-19-2008, 12:19 AM
  2. 1st CNC - Need Advise
    By gerryv in forum Benchtop Machines
    Last Post: 10-31-2007, 08:29 AM
  3. Buying Steppers
    By EMMKAY in forum Stepper Motors / Drives
    Last Post: 08-22-2007, 06:43 AM
  4. Buying advise, EZ Trak SX or Prototrak MX2
    By HammerHands in forum Bridgeport / Hardinge Mills
    Last Post: 11-03-2006, 11:43 PM
  5. Advise on buying a Lathe
    By crease-guard in forum Uncategorised MetalWorking Machines
    Last Post: 04-01-2006, 05:30 AM
