586,080 active members*
3,662 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Differential for Encoders?
    Nov 2005
    12
    Lightbulb Differential for Encoders?
    Greetings,
    I have to have two of my servos connected to my Gecko 320s with more than 6 feet of cable (I guess I will need around 12 feet).
    Do you think it might work without differential signals?
    The two servos in question have a US Digital encoder (HEDS-9100-A00).
    I assume I would need something that connects to the US digital encoder that converts the signal to differential, then another device that connects to the Gecko 320 that converts the differential signal back into what the Gecko expects.
    Can anyone recommend a source for reasonably cost signal differentials?
    Thank you!
    May 2005
    2502
    Sure it can work. I run more than 6 feet. You need to do a couple of things to maximize you chances.
    First, run shielded cable and ground the cable at you electronics enclosure end rather than at the machine.
    Second, since you're running HEDS encoders, be sure to add the bypass capacitors Mariss F. has recommended.
    I'm not having any problems since having done those two things.
    For more on the bypass caps for HEDS, go to this page:
    http://www.cnccookbook.com/CCMillCNCHome.html
    and search for HEDS.
    Cheers,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
    Jan 2006
    2985
    Its probably worth trying first without the differential signals.
    If you have problems, US Digital sells differential drivers/receivers to convert your encoder to differential signals. I don't know if you would consider it a resonable cost or not.
    If you are moderately electronically inclined, you can easily fabricate them yourself and save some money by using 26ls31 and 26ls32 chips. They can be had from digikey or elsewhere for a buck or less.
    Matt
  1. Wiring differential encoder
    By scrambled in forum CNC Machine Related Electronics
    Last Post: 09-06-2009, 07:56 PM
  2. Differential Encoder Signals
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 01-30-2008, 03:05 AM
  3. differential encoders with Gecko G320
    By jed102 in forum Gecko Drives
    Last Post: 10-02-2006, 10:37 PM
  4. Differential threads...
    By Chuck Pressure in forum MetalWork Discussion
    Last Post: 09-24-2005, 05:01 PM
  5. Synchro Differential Gen ??
    By Wannabe in forum CNC Machine Related Electronics
    Last Post: 03-24-2004, 01:36 AM
