586,693 active members*
2,991 visitors online*
    Jun 2009
    36
    Gecko G540 Relay Help
    Hello
    I just ordered my first Gecko G540 from Kelinginc.net and I would like to use a relay to turn my M12VC router on and off through Mach3, my question is what voltage does the G540 use for the relay, Do I need 48v @ ?amp
    and does anybody know a good place to get the relays? I believe the router is 120v@12amp.
    Jul 2007
    1602
    The G540 doesn't supply current to the relay, it merely switches a current path. According to the owner's manual, the outputs can handle 0-50V at 1A. I used a small 12V power supply to power my relays. See page 4 for a wiring diagram.
    http://www.geckodrive.com/upload/G54...4%20MANUAL.pdf
    bob
    Jun 2009
    36
    Quote Originally Posted by rowbare View Post
    bob
    Great, Thanks.
  1. Gecko G540 and Coolant Control Relay
    By MrAR15 in forum Taig Mills / Lathes
    Last Post: 07-10-2009, 03:01 PM
  2. Gecko G540
    By rotger in forum Servo Motors / Drives
    Last Post: 06-02-2009, 06:43 PM
  3. gecko g540
    By Teyber12 in forum Benchtop Machines
    Last Post: 05-31-2009, 08:23 PM
  4. Wiring diagram for Gecko g540 and cnc4pc C8 relay
    By blackrat in forum Gecko Drives
    Last Post: 04-25-2009, 11:22 AM
  5. G540 and cnc4pc C8 relay
    Last Post: 04-22-2009, 03:03 PM
