586,076 active members*
3,874 visitors online*
    Apr 2009
    NM-070 Travels
    Question for the NM-070 owners out there: is the listed 4.3" Y travel real? Is there a way to increase it at all?
    I'm looking at getting either a 135 or a 070. The 070 will do everything I need, except for the Y travel. The extra $2000 means I would have to wait quite a while longer to buy a NM-135.
    Jun 2007
    3891
    Quote Originally Posted by dcg571 View Post
    the spindle centre to the column way cover is about 4.75", so increasing the table travel doesnt necessarily do anything useful.
    for the record though, my kx1 (gen 1, but more or less the same) has 5.5" from spindle centre to column face without the bellows. the saddle will move 5.5" safely (it actually runs out over 8" but your pretty much off the dovetails so its stupid).
    you could put a 1" spacer block on the head to increase the usable travel to 5.5". id not recomend trying to squeeze more out because it creates alot of leverage on the Z dovetail, and with the drive screw behind the column makes for a type of mechanical backlash that can be bothersome.
  1. X3 increaseing travels.
    By southernexplore in forum Benchtop Machines
    Last Post: 11-12-2009, 04:37 AM
  2. X axis travels backwards
    By roadking in forum Fanuc
    Last Post: 04-18-2009, 01:07 PM
  3. Cutting parts larger than my travels will allow
    By project5k in forum Benchtop Machines
    Last Post: 03-06-2009, 11:31 PM
  4. X4 travels
    By turbogsx750r in forum Syil Products
    Last Post: 12-02-2008, 05:04 PM
  5. Sieg X1, X2, X1L true table travels?
    By boom in forum Benchtop Machines
    Last Post: 11-02-2006, 12:34 AM
