586,112 active members*
3,170 visitors online*
Results 1 to 11 of 11
    Oct 2008
    12
    haas tm1p 4th axis
    hi folks some help required please.
    I have a haas tm1p that had the 4th axis control module fitted before purchase. At the time i had no need for the actual 4th axis rotary/table , but, now do. Having priced the haas 4th axis they are out of my price range. (the job i have been asked to do is a prototype so dont want to invest huge amounts of money till i am sure it will pay for itself)
    Having looked around the net i have spotted some manual rotary table conversions with stepper motors fitted.
    Can some one please advise if this is an option and if so how do i go about connecting it up ?
    or any other non haas rotary thay may be feasable (cheaper)?
    As i have already the 4th axis option on my haas and a cam programme that will do 4 axis machining.
    Many Thanks
    Paul
    Jul 2005
    12177
    A couple of years ago a member on this forum tried to find out the information needed to interface a non-Haas rotary table to the Haas 4th axis in the machine without any success. Haas, not surprisingly, would not provide any information.
    I think you will find you are out of luck if you want to do true 4th axis machining. If all you need is indexing not continuous motion synchronized with the other axes you probably can Heath Robinson something together but this does not need the 4th axis in the machine.
    Oct 2008
    12
    thanks for the reply Geof,
    unfortunately it is "continuous motion synchronized" i require as i have been asked to machine a helix type piece.
    I have tried a practice part using the normal 3 axis. machine half then flip part 180 degrees. It works but due to the nature of the helix it cant machine it all.
    Paul
    Oct 2008
    12
    could there be hope ?
    was doing more searching and found this "haas cnc homemade indexer"
    http://www.youtube.com/user/pit202#p/u/6/v4q2hR4uDf4
    any ideas how he did it ?
    Paul
    Sep 2005
    47
    Thats not a true 4th axis, but an indexer. You can implement that with steppers and the serial output control, no need for the 4th axis option.
    As you see in the videos, the serial controlled indexer cannot turn in sync with the mill movements, but only as a separate step.
    Jul 2005
    340
    Quote Originally Posted by paul h View Post
    yes, I have , it is quite simple :
    Haas RS232 -> mine AVR controller -> UHU servo board -> DC Serco motor -> the mechanica part ;-)
    Few people (on this forum ) tried to make their own RS232 controllers for sale ( they posted a thread too ) , it is a while , and I didn`t saw any effects.
    __
    Peter
    May 2005
    925
    Hi Peter, found you here after finding at youtube the 4th axis/indexer you made for the haas minimill, I just purchased an harmonic drive for this same purpose. I saw in the coments that you saw the blue prints here at cnczone, but after looking for a while I did not found them, do you happen to remember where you got your inspiration?
    Pablo
    ● Distribuidor Syil en Argentina ● "www.syil.com.ar" ●
    Sep 2013
    54
    Re: haas tm1p 4th axis
    Any luck with figuring out this interface?
    Feb 2009
    6028
    Pretty easy to convert an old table over. I bought the cable set, motor, and zero return switch from Haas for the 5c 4th, installed everything to a old Boston matic table and set the correct counts. 1200 later all good to go.
    Sep 2013
    54
    I was hoping there was an easy way to do it with generic parts, it sounds like you just replaced all the electronic guts with the haas stuff? All that was only $1200?
    I have the A axis drive installed, with the indexer parts am I still limited to indexing or can I have 4 axis interpolating simultaneously?
    Feb 2009
    6028
    If you have the card, full 4th. I could have saved a couple dollars buying the motor right from yaskawa, however all this stuff from Haas literally just plugged in to each other, and no way I could have made that nice of cable set for what they charged.
  1. 2011 HAAS TM1P BATTERY REPLACEMENT??
    By hooperracing in forum Haas Mills
    Last Post: 08-18-2015, 04:00 AM
  2. Post for Haas TM1P and TL-2
    By BillEVM in forum CamWorks
    Last Post: 02-22-2014, 08:12 PM
  3. Replies: 4
    Last Post: 06-28-2013, 02:00 PM
  4. Need Alphacam post for Haas TM1P
    By jackshelton in forum Haas Mills
    Last Post: 03-10-2010, 10:16 PM
