586,075 active members*
3,834 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Micro-drilling, looking for drill chuck
Results 1 to 6 of 6
    Jun 2007
    168
    Hello Micro-drillers...
    I'm looking for a very small drill chuck to hold drill bits as small as .007"
    Any suggestions?
    Jun 2006
    3063
    Use a pin vise in a standard chuck?
    Albrecht claims that several of their chucks will go down to 0 inches, maybe ask them about their smallest series - 0-1/16".
    Mike
    Oct 2006
    669
    Use a Starret Pin Vise in an ER32 collet holder, or search for a Proxxon collet that will hold that size (you need a ridiculously high spindle speed to use that drill effectively)
    Quote Originally Posted by Freddy Bastard View Post
    Any suggestions?
    Oct 2007
    62
    micro drill
    I think most drills in the micro catagory have much larger shanks than the actuall drill diameter.
    A very good collet will work.
    Runnout will be another big issue besides the speed.
    Hmmm....... a Tormach EDM attachment, there's one for the R&D dept.
    Cheers
    Nov 2005
    145
    I was just doing this very thing this afternoon. I use a sensitive micro-drill adapter:
    http://www.use-enco.com/CGI/INPDFF?P...MITEM=290-1291
    for example. I pause the spinning spindle over the hole but actually do the drilling manually using this touch sensitive micro chuck. Its designed to handle these small drills with proportionate run-out and the tactile feedback minimizes broken bits. I haven't done any .007" holes yet but I did several
    .015's. They work pretty well. - Terry
    Jun 2007
    168
    I've drilled holes in aluminium as small as .005" on the Tormach. Everything is in the way you do it. Very small peck, with full coolant pressure and patience. But yes, the drill had a 1/8 shank.
    My old chuck was a Albrecht in a Er20 holder. After a miss step in Z axis... he is now dead...
    Thank's
  1. Using collet instead of drill chuck? for drilling steel
    By Rich05 in forum MetalWork Discussion
    Last Post: 07-14-2008, 04:53 AM
  2. pin vice / micro chuck question
    By ptxman in forum MetalWork Discussion
    Last Post: 05-27-2008, 02:06 AM
  3. Chuck Drill Chuck Alignment
    By TomV in forum Mini Lathe
    Last Post: 04-27-2006, 07:20 AM
  4. Micro drill adapters - alignment problems
    By buzzard in forum MetalWork Discussion
    Last Post: 02-01-2006, 02:58 AM
  5. Any Micro/Mill Drill Owners?
    By fireball08 in forum Benchtop Machines
    Last Post: 04-21-2004, 10:00 PM
