586,108 active members*
3,238 visitors online*
    Dec 2009
    7
    Smile Retrofit MORI-SEIKI SL1-A
    Hi guys!
    I have a FANUC AC-SPINDLE DRIVE A20B-1000-0692 and want to connect it
    to a FAGOR 8055 TC i need help with the analog i/o betwen the drive and
    8055
    Jul 2008
    67
    Quote Originally Posted by clintan99 View Post
    Hi guys!
    8055
    As far as hooking up the analog command to the spindle drive, its a simple thing. You can find the pin-outs from the 8055 in the installation manual. You also have an enable signal and possibly the spindle drive requires and M04 and M05 direction command, both of which the CNC can easily supply via the I/O.....
    Tell me more about what the Fanuc drive requires and I can help you determine where and how to hook up from the Fagor CNC perspective.
    Dec 2009
    7
    Exclamation
    thanks Fagor-Todd
    i dont have wiring diagram on the spindle drive an than idont sure how i
    connect it, the CN2 connector on the spindle drive is the problem.
    Fagor 8055 i have all installation manual thats no problem, do i realy need to
    connect the signal in rrc-1 on the FANUC AC-SPINDLE DRIVE A20B-1000-0692 ????
    rrc-1=spindle forward,spindle reverse,spindle orient,spindle auto,spindle manual, i wont 8055 to do that instead if it is possible
  1. Did Mori Seiki Buy Hitachi Seiki?
    By Billet Sean in forum Mori Seiki lathes
    Last Post: 05-05-2011, 04:12 AM
  2. Mori Seiki Sv-503
    By mr-seiki in forum Servo Motors / Drives
    Last Post: 06-04-2010, 02:52 AM
  3. mori-seiki
    By ron2008 in forum Mori Seiki Mills
    Last Post: 10-08-2008, 09:22 PM
  4. Help Required - Mori Seiki TL 2 (RETROFIT)
    By maxman in forum Uncategorised MetalWorking Machines
    Last Post: 04-08-2007, 03:22 PM
