586,892 active members*
4,164 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Puma 8S Spindle Amplifier error code 34
    Dec 2009
    We have a Puma 8s lathe P/N PM8S0295..we lost parameters while changing out batteries, but have manually input System para's per the print out we rec'd with the machine when we purchased it used. Have cleared most errors but the Spindle Amplifier is showing error code "34" (para out of range)..we have tried to input para 6519 to 00000010 and 00000110 which should cause a reset but have been unsucessful. Also having problem with error 408 and 409 re: Servo alarm serial error. Can anyone help ? Also is there any "Master list of Parameters" for this machine/controller. We have not input or changed any of the Diagnostic parameters since losing para's ?? Do we have to input both the System and Diagnostic para to get the machine back up and running ??
    Thanks for any input,
    Bob
    Sep 2008
    10
    AL-34
    Bob,
    Maybe this will help? from Fanuc Manual 65160
    Motor model code
    Control / Parameters
    0 / 6633 6733
    15 / 3133 3273
    15i / 3133
    16i/16 / 4133
    Data unit : –
    Data range : 220 or later
     If the motor model code is set to less than “219”, the
    parameter miss setting alarm (AL–34) is occurred. Because
    the parameter of ROM version 9D10 is not used at the ROM
    version 9D12.
     Please perform the automatic parameter setting for 9D12 by
    using the motor model code more than “220”.
    Find it, fix it, and leave it alone. But make sure you find it, make sure you fix it, before you leave it alone.
  1. Puma 240MB - Turret servo amplifier
    By Alex_Kozletsov in forum Daewoo/Doosan
    Last Post: 07-08-2009, 01:08 PM
  2. 940 pcb error puma 8s
    By inderan2005 in forum Daewoo/Doosan
    Last Post: 07-22-2008, 01:44 AM
  3. puma 8s 940 pcb error
    By inderan2005 in forum Uncategorised MetalWorking Machines
    Last Post: 07-18-2008, 02:45 PM
  4. G-Code program for amplifier card balancing
    By Jude1 in forum Uncategorised CAM Discussion
    Last Post: 07-20-2007, 11:54 PM
