i have a fanuc 21i MB control, a fanuc Oi - TC and a fanuc Oi - TB control and when I punch out a program to card it places double spaces between every line. Can anyone HELP,
Here is parameter 70.7 for the 0MC control:
ICR
1 : EOB is punched out as “LF when punching with IS0 code.
0 : EOB is punched out as “LF” “CR” “CR” when punching with IS0 code.
There is a similar one for the 21 control too.
Warren
www.uptimecorp.com
On the 0i, 18i, 21i, (and probably the 16i) it's parameter 100 bits 2 and 3.
7 6 5 4 3 2 1 0
x x x x 0 0 x x = LF CR CR (double spaced)
x x x x 0 1 x x = CR LF
x x x x 1 0 x x = LF
x x x x 1 1 x x = CR LF
Yours is probably set to 00. Change it to 01 or 11, and you should be good to go.
Hi I have a fanuc ot that is double spacing also what is parameter 70.7 not in either of my controls also have a omc?? looking for eob parameter to set to line feed only thanks
Capt Bob,
The parameter 0070, bit 7 (the one on the far left) listed in the 0MC Parameter manual is to control whether the control outputs LF (line feed) or LF AND CR( carriage return) in ISO outputs. Are you saying that you don't have parameter 70? I just checked both the 0MC and the 0MT books, and parameter 70 is only described in detail in the 0MC book. This implies that some vintages of lathe controls may have this parameter in a different place.
Warren
Uptime Electronics, Inc.
