586,067 active members*
5,239 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    Dec 2009
    6
    Arrow 500 problems
    Hallo all together
    iam new here and this is my first post here so please forget me some mistakes i make.iam a student from germany and my english is not the best.
    so now lets come to my problem
    i have get an arrow500 mashine with some problems
    1.the maschine was long time without cuurent and the only thinks i know is that the last error was 9036 filesystem corrupted
    2.the preowner of the machine formated drive c: and d:
    3. i get an backup disk with the machine witch contains folowing datas
    cnc_com.exe/Config.txt/Main.plc/plc_NV.sys/ax_off.sys/comp.mc/m_code.sp/Main.soc/s0000.sp/msg1.sys
    4. so what i have do till now ist to copy the main.soc to drive d:
    the Main.PLC to drive c: config.txt to c: but if i copy the s0000.sp data to c:
    and start the machine by booting the machine said error memory full
    5.my next problem is that i have no parameters (global;axis,etc.)
    maybe there is somebody out to tell me how to get the machine back to life
    and wich of the data i exactli i need and the proper way to get them into the machine.maybe somebody with a working arrow 500 who can send me the parameters and maybe the files i need and dont have.
    the machine has an CT control (maxax servodrive etc.)
    with best regards
    Dominik Haag
    Aug 2008
    386
    reloading CT FNC software
    I sent you a PM but you can ignore it.
    I have attached the procedure and files required to reload the entire system. You will need a PC running DOS with a serial port to reload it. The files required do not quite fit on a floppy so the procedure needs to be run from the hard drive.
    Joe
    Attached Files Attached Files
    Dec 2009
    6
    first thank you for the files.
    so now what i have tried
    i have an formated c and d drive
    i have copy the main.sp file on d:
    and the main.plc to c:
    by starting the machine an error ocurrs that the main.sp is not compiled with the correct compiler my revision is 2.98 yours is 2.568
    when i take my old main.sp file and your main.plc the machine starts
    but said no nv parameters in the moment i ad the s0000 file to drive c: the machine said error :memory full at startup
    can you maybe ecplain me the installation in the right steps????
    Aug 2008
    386
    I think you need to reload the entire system from the files I provided.
    Joe
    Dec 2009
    6
    yes i tried this i have formated all drives but i think the major problem is the main .soc i cant install yours because the wrong compilation by installing software on the test mode i have also the problem that the maschine check the flashdrives and said ok
    but than when it beginns to install the cnc.prc the maschine said cheksum error at line127.
    is there a possibility to clear all including the rev2.98
    and install completly you files????
    Aug 2008
    386
    I can't answer your question.
    The authority on these machines is Rob Varney at MAG Technologies.
    I used to have his phone number but cannot find it, not that it would help you much over there.
    http://www.mag-ias.com/
    Joe Mehl
    Oct 2009
    34
    Mr. Can you send me the serial number of your arrow machine and the serial number of your Acramatic 2100 control.
    That is because you lost the files in your CNC and you will need a complete software in your hard drive and to get the exactly software I need to know what model of numerical control do you have.
    CNCVEN
    Aug 2008
    386
    His control is a Control Techniques FNC not a Seimens Acramatic 2100.
    Joe
    Jan 2008
    48
    Quote Originally Posted by snap1202 View Post
    Here is some info on fixing the NV Parameters problem.
    Error 7001 NV Parameters (non-volatile) not set. To fix this;
    Control-D
    4 - MTB Mode
    Password: CM (it does not show as you type, Type in CM and press "enter" and it should pass this screen)
    3 PLC NV Param
    (the only two that have to be reset are NV1 and NV24
    NV1 ATC DOWN POSN = approx -121100 (specific to machine)
    NV24 MTB OPTIONS= 1
    (Note: use the data input key to enter above values. Enter key appears to work but values do not stay after exiting Diagnostics)
    Dec 2009
    6
    today i have tried all different softwares an files no i can boot up the machine without errors
    but now i have new problems i cant enter jog mod only auto or mdi on jog mdi is shown in the display
    an i have some new errors
    error 9170 axis not available status 1
    file: main .soc
    press a key to continue
    and
    error
    Machine not aligned
    i think i need an main.soc that was compiled with 2.98
    and an cnc.prc file
    what is the cnc.prc file?????can someone explain that ???
    Dec 2009
    6
    nobody out there who has an working arrow500 with rev 2.98 who maybe can
    make me an backupdisk with all installed files from the c: and d: drive???
    Dec 2009
    6
    after the memory modul was in italy still no working machine
    spindle drive shows -UU- that means undervoltage any idea?
    and after pressing any button to continue
    still
    file: main .soc
    and
    error
    Machine not aligned
    Aug 2008
    386
    Email Rob Varney with a description of the issue.
    [email protected]
    Joe
    desch Guest
    pb arrow 500
    still
    file: main .soc
    and
    error
    Machine not aligned
    I have the same problem with my arrow500. I reloaded it.
    I can't pull down the icon 3:maintenance and 4:MTB mode to finish the parameters reglages.
    please help me
    Aug 2014
    12
    Re: Arrow 500 problems
    Quote Originally Posted by scudzuki View Post
    Joe
    Hi, I have a machine that does not let me boot, my serial number is 7042-C00-94-0135, I bought this machine from a guy who used to make castings for a good price but the detail is that the parameters were erased due to a battery failure , do you think those files could help revive my slept machine ????
    If so, do you think I could have them tooo?? I would be really greatful
    Aug 2014
    12
    Hallo all together
    with best regards
    Dominik Haag
    Did you revive your machine??? if it worked could you tell me what steps did you follow to bring it back to life?? I am in the same situation noww lol
    Danke schon und schoenes Wochenende
    Hello scudzuki,
    I bought a used arrow 750. but it gives file system error. then I format the C drive intentionally in angry. I need to reprogram but I cound not find the installation files. do you have installation software for Arrow 750 like CT Arrow 500.zip
    Regards,
    Apr 2011
    112
    hello did you solve the parameter loading on FNC I have a similar problem
    Aug 2015
    32
    Quote Originally Posted by aventtini888 View Post
    Hi did you get your arrow up and running?
    Aug 2015
    32
Page 1 of 2 12
  1. Arrow 750 Control Problems...
    By ToolBreaker in forum Cincinnati CNC
    Last Post: 08-14-2014, 07:53 AM
  2. 2000 Arrow 500 boot problems
    By Ihauer in forum Cincinnati CNC
    Last Post: 10-25-2013, 03:12 PM
  3. having problems with arc's a2100 vickers arrow 750
    By dj_pigs in forum Cincinnati CNC
    Last Post: 11-23-2012, 03:23 PM
  4. Arrow 500 Spindle orient problems
    By kstocklin in forum Cincinnati CNC
    Last Post: 01-06-2012, 01:57 AM
  5. arrow 750 z fault problems
    By chaz6966 in forum Cincinnati CNC
    Last Post: 11-26-2011, 02:14 AM
