586,395 active members*
2,807 visitors online*
Thread: lubrication
    Dec 2006
    5
    lubrication
    I have a techno lc4896 and have the grease/oil sheet but wonder if there is any substitutions that can be made. For example the sheet recommends Renolin CLP 100 and I have a bottle of gear oil SAE 75W-90. Are these at all compatible? I have multi-purpose lithium grease that I use for the y-axis ballscrew. Would be nice to have a clearer document for what can be used. Also, it would be great to see some videos of lube maintenance.
    Nov 2005
    7
    I just recently re-greased using this & a grease gun, works great, no problems yet
    http://www.slick50.com/products/OtherProducts.htm
    Apr 2008
    80
    lubricating x axis
    Applying lubricant to the rails inside of the Gantry with an "acid brush" doesn't seem like the most effective solution. Is there a spray lubricant that is suitable for this job? It's hard to know if the rails inside receive enough lube!
    Grant
  1. Taig way lubrication
    By CS900 in forum Taig Mills / Lathes
    Last Post: 06-26-2008, 07:37 PM
  2. One shot lubrication?
    By 79TigerPilot in forum Bridgeport / Hardinge Mills
    Last Post: 05-20-2008, 05:06 AM
  3. Lubrication
    By bohica in forum Charter Oak Automation Support Forum
    Last Post: 04-29-2007, 07:13 AM
  4. Ballnut lubrication
    By Haydn in forum Linear and Rotary Motion
    Last Post: 12-08-2006, 03:36 AM
  5. Lubrication
    By BeerFizz in forum Benchtop Machines
    Last Post: 11-10-2005, 01:25 AM
