I am using a G540 hooked up to my Dell Dimension E510. The Dell did not come with a parallel port and so after buying and installing a couple of different PCI parallel ports, I found one seems to work and gives excellent pulse ratings on the Driver Test. Hooked up my controller box and was greeted by the fault light. Downloaded 540B.xml... still a fault light. Disabled the charge pump..GREEN LIGHT! The e-stop also functions properly.
Now my question. I have read in several posts that the parallel port needs to be configured to EPP in the BIOS or some functions of Mach3 won't work properly. Since there is no parallel port on the motherboard of my dell, the pci parallel port doesn't show in the Bios, and I can't change anything (I even downloaded the latest Bios)
Since everything so far seems to be working, should I continue on the project or should I find an old computer with a mother board parallel port? I would like to use the charge pump. Is there some way in the device manager that I can verify the correct settings? What would I look for? Thanks...
