Hi, I just have a quick question about setting up the step / direction interface from EMC to my Viper drives. Since EMC allows you to choose which output each parallel port pin is used for, could I just wire up a 25 pin connector like show below and run each Viper drive from my computers parallel port? Since the Viper step / direction interface is opto-isolated on the board, is there any reason to use a separate breakout board? Thanks.
2 - X Step
3 - X Direction
4 - Y Step
5 - Y Direction
6 - Z Step
7 - Z Direction
8
9
10
11
12
13
14
15
16
17
18 - X Step (ground)
19 - X Direction (ground)
20 - Y Step (ground)
21 - Y Direction (ground)
22 - Z Step (ground)
23 - Z Direction (ground)
24
25
