586,036 active members*
4,109 visitors online*
Results 1 to 15 of 15
    Oct 2009
    118
    Milling macros
    Can someone with an 0i control for a mill post these macros?
    Custom Macro B Canned Cycles
    The Custom Macro B canned cycles are fully tested examples of macros that
    you can use immediately, or copy and modify to implement your own custom
    cycles.
    O9170 Outside frame milling
    O9171 Inside frame milling
    O9172 Pocket frame milling
    O9173 Face milling
    O9174 Outside circle milling
    O9176 Inside circle milling
    O9177 Pocket circle milling
    O9179 Slot milling
    O9180 Row pattern drilling
    O9190 Rectangular frame drilling
    O9280 Bolt-hole circle drilling
    O9170 (G170 OUTSIDE FRAME MILL)
    #2=#4003 (G90/G91 MODE)
    #130=#5041(INITIAL X POS)
    #131=#5042(INITIAL Y POS)
    #132=#5043(INITIAL Z POS)
    #133=#[2000+#4107](ACTIVE RADIUS)
    IF [#2 EQ 91] GOTO 3 (INCREMENTAL MODE)
    #130=0
    #131=0
    #132=0
    N3 #130=#130+#4 (FINAL X POSITION)
    #131=#131+#5
    #132=#132+#6 (FINAL Z POS - R PLANE)
    IF [#13 NE #0] GOTO 4
    #13=0
    N4 #7=#7-2*#9 (LENGTH - RADIUS)
    #8=#8-2*#9 (WIDTH - RADIUS)
    #9=#9+#13 (RADIUS+FINISH ALLOWANCE)
    IF [#14 NE #0] GOTO 5
    #14=#12 (FINISH FEED)
    N5 IF [#15 NE #0] GOTO 10
    #15=0.5*#12 (PLUNGE FEED)
    N10 IF [#16 EQ #0] GOTO 20 (STEP DEPTH)
    IF [#16 EQ 0] GOTO 20
    #23=#10/#16
    #17=FIX[#23] (ROUND OFF)
    #23=#10-#17*#16
    IF [#23 EQ 0] GOTO 25
    #17=#17+1 (NO. OF STEPS IN DEPTH)
    GOTO 25
    N20 #17=1
    #16=#10
    #23=0
    N25 G90 G00 Z#132 (MOVE TO R PLANE)
    G00 X#130 Y[#131-#8/2-#9-#11] (START POSITION)
    G41 G91 G01 X#11 F#12
    G03 X[-#11] Y#11 R#11
    (START OF MILLING CYCLE)
    N1 WHILE [#17 GT 0] DO 1
    IF [#17 GT 1] GOTO 18
    IF [#23 EQ 0] GOTO 18
    #16=#23
    N18 G01 Z[-#16] F#15(PLUNGE)
    G01 X[-#7/2] F#12 (MILL)
    G02 X[-#9] Y#9 R#9
    G01 Y#8 (WIDTH)
    G02 X#9 Y#9 R#9
    G01 X#7 (LENGTH)
    G02 X#9 Y[-#9] R#9
    G01 Y[-#8]
    G02 X[-#9] Y[-#9] R#9
    G01 X[-#7/2]
    #17=#17-1
    END 1
    N19 IF [#13 EQ 0] GOTO 30 (START OF FINISH CYCLE)
    #9=#9-#13 (DECREASE RADIUS BY FINISH ALLOWANCE)
    #11=#11+#133 (ADJUST CLEARANCE BY TOOL RADIUS)
    G03 X[-#11] Y[-#11] R#11
    G01 X[2*#11+#13]
    G03 X[-#11-#13] Y[#11+#13] R[#11+#13] F#14
    G01 X[-#7/2] (FINISH)
    G02 X[-#9] Y#9 R#9
    G01 Y#8 (WIDTH)
    G02 X#9 Y#9 R#9
    G01 X#7 (LENGTH)
    G02 X#9 Y[-#9] R#9
    G01 Y[-#8]
    G01 X[-#7/2](END FINISH CYCLE)
    #11=#11-#133(ADJUST CLEARANCE BY TOOL RADIUS)
    N30 G03 X[-#11-#13] Y[-#11-#13] R[#11+#13] F#14
    G40 G01 X[#11/2]
    G90 G00 X#130 Z#132(Z MOVE UP)
    G#2 (PUTS BACK INTO G90/G91 MODE AS FOUND)
    M99
    Oct 2012
    7
    macros
    Nice macros ! I would love to have these for slot milling. Anyone ?
    Jan 2013
    4
    Quote Originally Posted by pitri View Post
    I do not currently have any slot milling macros, but would you be interested in trying out one of my 3D custom macros. Here is the first macro I ever wrote and it can machine 1/2 a sphere or cap any size radius on any size diameter.
    O7777(CAP 0-90 DEG FULL RAD. OD PART)
    (ABSOLUTE SURFACING MACRO)
    (START OF TANGENT/ TOP OF PART)
    (END OF TANGENT/ OD OF PART)
    (WORKS)
    (FORMAT G65/G66 CDTSKRZF)
    (C = #3 - CUSP HEIGHT/ DEG. OF ROTATION)
    (D = #7 - TOOL DIAMETER)
    (T = #20 - TOOL RADIUS/ BALL OR BULL)
    (S = #19 - PART DIAMETER)
    (K = #6 - PART CORNER RADIUS)
    (R = #18 - R PLANE)
    (Z = #26 - Z START ZERO)
    (F = #9 FEEDRATE)
    IF[[#19/2]LT#6]GOTO1000
    #100=0
    #101=#6+#20
    #102=#3
    IF[#102GT15.]THEN#102=15.
    #102=ROUND[90./#102]
    #102=90./#102
    #103=#5001
    #104=[#103-.1]-[[#7/2]+[#19/2]]
    #105=#5002
    #113=#105
    #115=[#105+.1]+[[#7/2]+[#19/2]]
    #145=0
    IF[#7EQ[#20*2]]GOTO1
    #105=#105+[[#7/2]-#20]
    #145=#145+[[#7/2]-#20]
    N1G0G90X#104Y#115
    Z[#26+.1]
    G1Z#26F#9
    #106=#5003-#101
    WHILE[#100LE90.]DO1
    IF[#100GT90.]GOTO100
    #107=#105+[SIN[#100]*[#101]]
    #147=#145+[SIN[#100]*[#101]]
    #108=#106+[COS[#100]*[#101]]
    IF[#6EQ[#19/2]]GOTO10
    #107=#107+[[#19/2]-#6]
    #147=#147+[[#19/2]-#6]
    N10#100=#100+#102
    G1Z#108F#9
    G41Y#107
    X#103
    G02J-#147
    G03X[#103+.1]Y[#107+.1]J.1F[#9/2]
    G0Z[#108+.1]
    G40X#104
    END1
    N100G0G90Z#18
    X#103Y#113
    M99
    N1000M00( PART CORNER RAD. TOO BIG )
    Sep 2009
    Re: Milling macros
    Hi everyone,
    So I have been wanting to create a macro for pocketing starting in the center of the pocket, and I'd like to dedicate variables for certain call outs, such as pocket length in x, pocket length in y, z depth, tool stepover, pass per depth, corner radius, etc.. My problem is I'm struggling with how to start out my sub routine so my cutter starts on center and my tool will stepover the amount I specified in a variable. Below is what I will be calling out for variables. Any help or thoughts on this would be greatly appreciated.
    #124= #24 ( X CENTER )
    #125= #25 ( Y CENTER )
    #126= #26 ( Z CENTER )
    #104= #4 ( I OR X LENGTH )
    #105= #5 ( J OR Y WIDTH )
    #106= #6 ( K OR Z DEPTH )
    #118= #18 ( R OR CORNER RADIUS )
    #117= #17 ( Q OR DEPTH OF EACH PASS )
    #121= #21 ( U OR DEPTH OF FINISH PASS )
    #120= #20 ( T OR TOOL NUMBER )
    #109= #9 ( F OR CUTTING FEED RATE )
    #108= #8 ( E OR PLUNGE FEED RATE )
    #107= #7 ( D OR PERCENT OF CUTTER DIA )
    May 2017
    Re: Milling macros
    Newbee!
    Is there such a thing as macros for dummies?
    I also need help with using the Renishaw probe on my Haas VF-5, can anyone point me in the right direction?
    Sep 2009
    Re: Milling macros
    DynoDean
    what do you need help with on the probe?
    Feb 2018
    7
    Re: Milling macros
    Hello James
    That is a nice 1/2 Sphere Program you have got there. Is there any chance you can do a Mach 3 friendly version. As it stands Mach 3 doe's not like the IF statement in the program.
    Jun 2015
    4154
    Re: Milling macros
    hy pkcnc, i have many parametric codes ... if you wish, i can create one for you
    i don't have experience with mach 3, but i can start by generating the toolpath, then customize it with mach 3 g-code syntax ( considering that you provide it )
    this means that you can not write all the logic inside the machine program, thus i guess that mach3 uses only linear code
    so, all the logic has to be somewhere else, like in a software application ... no problem, consider it done to begin, i need to know part shape before and after operation + tool shape
    Feb 2018
    7
    Hello
    Basic shape is 1/2 a sphere, diameter is 100mm. Using a ball endmill 12mm diameter. Would be great if it can be done. The sphere is machined from a block 120 x 120 x120mm.
    Jun 2015
    4154
    Re: Milling macros
    so you wish for half a sphere, with diameter 100 ? tool o12 ? ok
    if i give you the toolpath in xyz, can you make it work on your machine ? because i can't, i don't know the g-code for mach3
    also, please choose a strategy :
    ... cut a circle, then make a step in Z, cut another circle, then make a step in Z, and so on
    ...... or
    ... continous helix
    i can deliver a parametric for the finishing
    for roughing it would take me longer ... hmm ... what do you say ? are you ok only with finishing ? kindly
    Feb 2018
    7
    Hi Toolpaths will be fine. Z step strategy for roughing out. And the continous helix for finishing if you can. Thanks.
    May 2017
    Re: Milling macros
    I posted this in 2017, I just got a responce this week and it was to the post below this one?
    Anyway I am looking for a soft wear program to use my Renishaw probe on my VF-5 for reverse engineering parts. A point cloud that can be turned into a solid.
    I want to output from the Haas controler to my laptop drawing program (BOB/CAD CAM)
    Sep 2018
    27
    Re: Milling macros
    Quote Originally Posted by DynoDean View Post
    I think MeshLab can do the job, and its free !
    You have to create a valid .xyz file from your point cloud, then search for the following page : "How to Create an STL file from a XYZ file in MeshLab" which give the procedure to obtain an stl from the point cloud.
    The resulting stl can be imported in any CAD i think.
    May 2007
    1003
    Re: Milling macros
    Newbee!
    Only 5 years too late to the party, but maybe a help for someone else. Get the book CNC Programming Using Fanuc Custom Macro B by S. K. Sinha. He does an excellent job of explaining Macro B programming and gives some useful examples.
    Jun 2015
    4154
    Re: Milling macros
    Quote Originally Posted by PKCNC View Post
    The sphere is machined from a block 120 x 120 x 120
    hy pkcnc please check attached : roughing from square + helix finishing
    but z step finishing may be better, because it requires only g2/3, while helix finishing will break a g2/3 in many linear segments
    sorry for the late reply, only recently i remembered this / kindly
  1. macros
    By gtrrpa in forum Mori Seiki Mills
    Last Post: 04-22-2011, 07:54 PM
  2. macros
    By georgebarr in forum Mach Mill
    Last Post: 06-03-2009, 02:11 PM
  3. help with macros
    By gj83 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-12-2008, 02:42 AM
  4. Help with macros
    By afterburn25 in forum Haas Mills
    Last Post: 04-09-2007, 02:19 PM
  5. macros
    By toyoda in forum Uncategorised CAM Discussion
    Last Post: 05-30-2004, 10:56 AM
