It's a copy of the lovely little Emcoturn Austrian lathes. Sweet design. Every $ of manufacture is put to productive use with no bling, just solid functionality.
I had not had my 9x30 apart far enough to see there are oil grooves on the cross slide. You'll be able to put a one shot oiler on it very easily, if you so choose. I really love the one on my mill.
Probably the one thing about the basic guts of these little lathes I would change is to convert to tapered dovetails. Adjusting all the little setscrews is just a nuisance. Having a tapered dovetail would be sweet.
Somewhere, once upon a time, I saw a write up where someone had done that, but it's been lost in the mists of time.
I'd love to see one of these CNC'd with a nice 2 or 3 HP VFD motor on it. I swapped in a treadmill motor on mine, and that's been really sweet. But I think you could feed one of these little monsters more power and the CNC would love it. If nothing else, you'd need to start with more power and a nice little VFD to maintain enough power over all the speeds that you aren't changing pulleys all the time. Just a "Hi-Lo".
The other thought I'd had while entertaining the notion of building it a bigger spindle was to just make a dedicated 5C spindle like a Hardinge. But then I thought, why not 16C? That'd be sweeeeeeeeeeeeetttttttttttt!!!!!!!
:cheers:
With your work CNC's, you should be able to turn out a nice spindle. Probably could even hard turn something that's pre-hardened. Be sure to turn your taper with the spindle in the bearings so it's true to their axis, but I bet you knew that.
Cheers,
BW
Try G-Wizard Machinist's Calculator for free:
http://www.cnccookbook.com/CCGWizard.html
