586,071 active members*
4,000 visitors online*
Thread: Sram backup.
    Mar 2008
    31
    Sram backup.
    I can't get a Mori with an 18i control to do a sram backup. The first 512mb file does fine. The second file gives me a sram parity error. There have been no problems with this control. Runs fine with no problems.
    What is this error for and how do I get around it??
    Nov 2004
    53
    If you are trying to back up to a memory card and the sram data has a parity error you must use the serial port.
    Then restore the file from the port and should solve the issue.
    May 2009
    181
    Quote Originally Posted by debco99 View Post
    you cant make an sram back up with the port...
    Anways.. you have 2 choices.. 1 being do a backup via rs232 by downloading all the parameters separately.
    OR
    punch out all your programs O-9999... if you get a 910 ram parity it means its the program storage area of the sram..
    so ur gonna need to power the control on holding the DELETE key.. it will clear all the programs so try to back up as many as possible.. including all 9000 programs
    Oct 2009
    297
    Clear memory
    To solve this issue.
    You must do a backup using the rs232. You cannot use the sram card at this time.
    Backup EVERYTHING.
    Then you´ve got to clear memory.
    Upload EVERYTHING.
    Now you can use the sram card.
    Since your machine is working fine, I suggest not to do this procedure.
    Alexfanuc
    Mar 2008
    31
    Well, I will use the HandyFile to back with serial port then. Just SRAM is so short and sweet..lol
  1. Replies: 4
    Last Post: 07-12-2012, 08:34 AM
  2. SRAM FOR DOOSANZ290SM
    By CHAD LAWSON in forum Fanuc
    Last Post: 10-30-2008, 06:32 PM
  3. New sram backup question.....
    By ajm100a in forum Fanuc
    Last Post: 04-23-2008, 09:19 PM
  4. SRAM Backup
    By msaiprasad in forum Fanuc
    Last Post: 12-06-2007, 08:04 AM
  5. Download to SRAM
    By Bluesman in forum Fanuc
    Last Post: 02-16-2007, 05:49 PM
