586,036 active members*
4,343 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > Citizen M series basket and counter Question
    Aug 2007
    13
    Wondering if there is a #xxx variable for the parts counter and what part it's on. Would like to be able to program the machine using a IF #xxx(counter set at variable) EQ #xxx (part it's on)GOTO69 and instead of the machine dumping the part going to T2200. You could prob us a loop but then the counter would have to be set a what the loop is programmed at. Just wondering if anyone has ever looked into this or done it. We run Older M's from late 90's to the new 3m3's and 3m5's. Thanks
    Feb 2008
    267
    Even if there is registry value for the machine counter, you would be better off just coding it with #500 values and and reset after every so many parts.
    The machine counter can be reset too easily and your results would/could be upredictable.
    If you use #500's and count you could dump every nth part then reset and start counting again.
    Good luck
    304
    I agree with Proprocess, using the variables will be more consistant.
    I am attaching a sample program which was used on the old M1-20 and would work the same on the new controls also. This was using a counter I created to eject parts into a tube, but, once the tube was full, by know amount, I would start ejecting into another tube located in a second turret position.
    Attached Files Attached Files
    Aug 2007
    13
    Thanks for the replies and I will give that a try Cogsman thanks
  1. Series I Homing Question
    By ranchak in forum Bridgeport / Hardinge Mills
    Last Post: 12-19-2009, 12:20 AM
  2. BP Series 2 Pneumatic Question
    By loedward22 in forum Bridgeport / Hardinge Mills
    Last Post: 07-16-2009, 01:42 PM
  3. Boss 5 Series 1 stepper question
    By tpres500 in forum Bridgeport / Hardinge Mills
    Last Post: 02-18-2007, 07:58 AM
  4. Fanuc Series O-M DNC question
    By Blu91Z28 in forum Fanuc
    Last Post: 06-30-2006, 05:45 PM
  5. POtting Balls into the basket---best mechanism?
    By shaiqbashir in forum RC Robotics and Autonomous Robots
    Last Post: 03-24-2006, 06:26 PM
