586,094 active members*
3,926 visitors online*
Page 1 of 3 123
Results 1 to 20 of 43
    Aug 2006
    8
    MDF Feed Rates?
    I'm trying to figure out an optimal feed rate for cutting 3/4" thick MDF.
    Currently, my machine uses a Hitachi M12VC with a up spiral 1/4" end mill. I've tried quite a few combinations of rpm, feed rate and pass depth. All to varying degrees of success. I'm curious what others have tried.
    Sorry if this is a repost subject, pointing me in the right direction is much appreciated.
    -clamps
    Oct 2008
    1147
    It's going to come down to the stiffness of your machine. I have a weak Z axis so I can only take cuts of about 50 ipm at a .07 depth. That's on the sad side but I'm happy. Any deeper and I end with bad edges. Others can do it at 125 ipm and in 2 passes. I think the best formula for your tool life is going to be the deepest you can go at the lowest RPM and fastest IPM. The bigger the MDF particles you create the longer your tool will stay sharp. Bigger particles will take more heat with them keeping your tooling sharp. Too low of a feed rate and your just dulling your endmill because of all the friction. That's how I understand it.
    Aug 2006
    8
    Quote Originally Posted by FandZ View Post
    FandZ : Thanks for the feedback. That is what I've been finding. Right now I've been running fairly fast: 80 IPM at only 0.125" depth cuts. I may try backing off the RPM next.
    I'm quite surprised with how cool the end mill is staying. After running it for 10+ minutes, when the tool slows to a stop, its only mildly warm to the touch.
    Yes dulling is my biggest annoyance at the moment. Its making running the machine quite expensive. Optimizing tool life is my goal.
    Thanks again for the reply.
    -clamps
    Quote Originally Posted by clamps View Post
    FandZ : Right now I've been running fairly fast: 80 IPM at only 0.125" depth cuts. I may try backing off the RPM next.
    That's actually very slow. My machine also has a bit of flex in the Z axis, so I limit my depth to .125-.188 per pass. I cut at 135-150ipm, and about 12,000 rpm. I get pretty decent tool life. 150ipm is as fast as my machine can go, or I'd cut faster.
    Depth of cut really depends on how rigid your machine is, as well as the power of your router. If your machine can take it, try cutting the 3/4" in either 2 or 3 passes at at least 125ipm, and 10,000-12,000 rpm. You should get much better tool life.
    Oct 2008
    1147
    Gerry, how many starts are on your lead screw? I'm thinking about upgrading to a faster screw on my next machine.
    1/2-8 2 start.
    Jul 2003
    276
    What kind of endmills HSS or carbide? I used a few HSS but found they dulled fairly quick. Switched to solid carbide, they seem to last forever.
    Apr 2005
    462
    I've done some tests today cutting a slot, 1000mm/min at around 10000rpm using a 4mm spiral upcut (albeit with a rather "slow" helix, better for steel than mdf) at 3mm depth and I've created the worlds first zipper out of mdf! hehe, the little hairs from both sides of the cut slot intermesh so nicely it looks like a zipper. no this is too slow I'm thinking. the finish is horrible, all dust has remained in the cut, nothing has been evacuated which is odd.
    mdf is a pain to cut cleanly.
    I cut at 3500mm/min at 10,000 rpm with a 6.35mm upcut spiral. You always get some dust in the cut with MDF, unless you blow compresses air on it while cutting. The smaller the bit, the worse it'll be.
    Oct 2008
    1147
    Another odd thing about MDF, I swear each sheet of MDF cuts differently than the next. I'm useing the same tooling, speeds etc, and the edges are coming out nearly perfect. Last board of mdf I got required me to hit it with a sanding block around the edges with every piece.
    Aug 2006
    8
    Is there a definitive way to tell the "sharpness" of a tool?
    The end mill I've been using feels sharp to the touch, but it is clearly making different sounds through the same cuts I've been making and I think slowing down the router during fast straight passes.
    Mar 2015
    70
    Re: MDF Feed Rates?
    hi Gerry
    my machine maxes out at about 600mm/min. Can you please give advice on feedrate for milling mdf; say 1/2 inch mdf with 2mm downcut spiral endmill; and pass depth of 1 or 2 mm.
    currently at 12000 rpm it is making it as dust. will my bill pentz dust extractor cool the bit too ??
    best regards.
    Live long and Prosper.
    Re: MDF Feed Rates?
    Can you slow the RPM down further? At 600mm/min (and even much faster), you'll never actually get chips from MDF. You'd need to be cutting 15-20x faster.
    Especially with a downcut, which packs the chips in the kerf, and recuts them on the next pass.
    No, the dust collector will not cool the bit.
    Mar 2015
    70
    Re: MDF Feed Rates?
    Hi Jerry thanks
    yes my water cooled spindle is on VFD. It can go to say 3000 even. What will happen to the finish.
    I also used the feed and speed calculator from this site. it is giving way higher RPM's. I wonder why.
    Mar 2015
    70
    Re: MDF Feed Rates?
    Actually my ball screws are 1-start, 16mm dia 5 mm pitch. and steppers are 2.2Nm on 36 V
    Mar 2015
    70
    Re: MDF Feed Rates?
    should i go 10X slower; i.e., 1200 RPM ??
    Feb 2011
    37
    Re: MDF Feed Rates?
    It's not a good idea to use compressed air on MDF
    REF; https://the-cnc.blogspot.co.uk/p/sim...extractor.html
    Re: MDF Feed Rates?
    Imo, it's a very good idea, if you want to get the chips and dust out of the cut.
    I would not run your spindle below 6000-8000 rpm, or you risk damaging it.
    I wonder why you can not get more than 600mm/min out of your machine? It should be capable of more than that.
    All you can really do is set your spindle to 8000 rpm, and the feedrate as high as possible. It would be better if you could cut at 3000-5000mm/min.
    Feb 2011
    37
    Re: MDF Feed Rates?
    " An extractor is needed to take away dust or fumes from the cutting area, especially when machining MDF.
    MDF is a harmful substance and a classified carcinogen, it contains among other things, formaldehyde. and is a banned substance in many European countries."
    Re: MDF Feed Rates?
    You still need good dust collection, but compressed air can actually assist in dust collection, and extend tool life.
Page 1 of 3 123
  1. cutter leaving feed lines at high feed rates-walter prototyp end mill
    By shimmwagen in forum DNC Problems and Solutions
    Last Post: 02-07-2014, 11:44 PM
  2. Replies: 0
    Last Post: 01-23-2014, 08:54 PM
  3. Feed rates
    By forrey in forum Novakon
    Last Post: 11-29-2013, 04:55 AM
  4. Feed rates on ENC-16, ENC-164
    By The Pininator in forum CNC Swiss Screw Machines
    Last Post: 01-25-2011, 01:48 PM
  5. Feed rates?
    By Rainman229 in forum G-Code Programing
    Last Post: 02-23-2007, 06:47 PM
