586,060 active members*
4,376 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > V23 Download - CAM restricted?
Results 1 to 8 of 8
    Feb 2006
    33
    Guys,
    I'm interested in buying V23, thought I'd download the demo from the BobCAD site and have a play first. Now, I haven't waded through the tutorials etc yet, but having a play around on the screen I notice the vast majority of menu options listed under the DataCAM tree in relation to machining ops, tool paths etc etc are greyed out. I'll go have a proper read later, but can anyone confirm whether the download demo version is restricted in the CAM department at all?
    Cheers guys.
    Feb 2009
    68
    Never heard of that before i know that you could post code but not be able to save it.
    David.
    Jun 2008
    1838
    Quote Originally Posted by Alfonzo View Post
    Guys,
    Cheers guys.
    If you have the Demo download I think it depends on which one you downloaded but you should be able to "Test drive" all the options, otherwise what`s the point of the Demo???
    They are all available (Not "Greyed out") in my software when i "Demo" mode!!
    I do know that you can only Post I think it is 20 lines of "G" Code and also any drawing done in "Demo" mode can`t then be opened later in the Licensed mode and vice versa.
    Also you don`t get the full run of the Verify Simulation nowadays.
    Regards
    Rob
    Dec 2008
    4548
    It's been awhile since I was in the "demo software" section, but there used to be different "versions" of demo you could download. Like Basic mill only....up to "everything". Maybe revisit the demo software page and see if you notice anything like that. You could also try giving them a call and see if they have any direction.
    General,
    Remember that the "Demo Softwares" are different than your "full install" running in "Demo Mode". (I beleive)
    Burr
    Feb 2006
    33
    Cheers for the thoughts guys. Turned out to be due to me not setting the compatability of V23 to XP (I'm runnning Vista) and giving the software admin rights. Looking better now.
    Jun 2008
    1838
    Quote Originally Posted by BurrMan View Post
    General,
    Burr
    Ahhhh, the old Vista compatability thing, I keep forgetting about that as I never used Vista, stuck with XP!!
    Burr
    Been a while since I was in amongst the "Demo Software" downloads myself and yes I think you are right in that they used to have all those weird levels to download, however I`m sure I read a Post somewhere that they had sort of "consolidated" them into just a couple now!! Could be wrong, like I said, been a while!!!!
    Regards
    Rob
    :rainfro::rainfro:
    Dec 2009
    41
    Yah I found the V23 demo to by a tease. You can generate a 2D path, but not 3D.
    Apr 2008
    1577
    Just to be clear, I haven't tried the demo in a while. I do recall something about being connected to the internet for the 3D toolpath demo to work. Make sure Anti-Virus isn't blocking BobCAD from connecting.
    Again, that's only for the demo. Running in licensed does not require an active internet connection.
    Things might have changed since the demo I downloaded.
  1. download plc
    By hongjianming in forum Fanuc
    Last Post: 08-21-2009, 12:40 PM
  2. re download of x2
    By woffler in forum Mastercam
    Last Post: 05-15-2008, 02:39 PM
  3. Dynapath 20 Download
    By CharlesM479 in forum BobCad-Cam
    Last Post: 03-01-2007, 02:51 AM
  4. New Download Available
    By WarrenW in forum News Announcements
    Last Post: 12-26-2006, 11:21 PM
  5. won't download
    By turmite in forum Uncategorised CAM Discussion
    Last Post: 01-07-2004, 05:20 PM
