586,670 active members*
3,284 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > Tailstock Advance on Hitachi Seiki Hi Tec-Turn 23SIII
    Dec 2009
    Does anyone have a program example of Advancing the Tailstock for the Hitachi Seiki Hi Tec-Turn 23S III with a Seikos control. My programming manual has M25, M26, M27, and M28 as codes. I am not able to get the tail stock to move manually either. Some help would be greatly appreciated.
    Apr 2011
    these are the m codes i use m25 forward,m26 all the way home and m28 timer home if i where you i would check to see if power is going to the motor and if it is its probably rusted up
    Apr 2011
    contactor MS-5F &MS-5R should be the ones that drive it through overload OL-5 see if there is anything happening here and check overload has not tripped
  1. Mori Seiki SL-65 tailstock problem
    By brad63av in forum Mori Seiki lathes
    Last Post: 03-01-2015, 05:41 AM
  2. Hitachi Seiki
    By j_love in forum Mori Seiki lathes
    Last Post: 03-23-2012, 10:32 PM
  3. Did Mori Seiki Buy Hitachi Seiki?
    By Billet Sean in forum Mori Seiki lathes
    Last Post: 05-05-2011, 04:12 AM
  4. Hitachi Seiki
    By wiks in forum MetalWork Discussion
    Last Post: 10-11-2008, 07:20 PM
  5. tailstock advance code
    By nitrosnfr in forum MetalWork Discussion
    Last Post: 08-29-2007, 06:44 AM
