Thought I'd post my (cast iron) scraping eductation so far, some hard learned, some passed along by others with experience. Hoping to save others my frustrations and mistakes.
First, hard won lesson:
Never use prussian blue spotting fluid; if you have those little tubes from permatex or wherever, give or throw them away. I have 2 brand-new tubes if anyone wants them.
*I forgot just how hard it is to clean up anything after using it. Impossible to get stains out of anything but metal.
*Use Canode spotting ink. Non-drying, water soluble ink, works great. I clean up my straight edges and work with just a damp cloth or running water. Got a stain out of the carpet fairly easily too.
Dapra sells it, but were very expensive with all the other related items, so I bought mine from Volk.com for $10 for 1/2 pint (lifetime supply).
2nd:
You'll need a rubber roller (2" to 3" wide, your preference) to apply the ink. Not very critical, I bought one from the craft store for $2 as opposed to spending bucks online.
3rd:
Try to use a carbide scraper to reduce your downtime dressing the tip.
There is nothing wrong with using a steel scraper from Enco.com, but you'll need to grind a radius on the nose to avoid end-gouging.
4th:
Scraper dressing is all important. Dress the tip with a 140-300 mm radius to begin your work or large areas and dress it to 60mm radius for spotting those canode spots toward the end of your journey. A DVD/CD is a perfect template for 60mm radius.
5th:
Scraper dressing pt.2
You must dress the tip so that the scrapes have no streaks or scratches (not issue with steel scraper). Grind the nose of the tip between 1-4 negative degrees, and grind it so the working edge "sees" the lead side on the grinding wheel to prevent carbide breakdown, then flip the tip over and repeat. The finished tip will have a little edge-nose to it, and the carbide won't break-out, leaving nicks. Can't stress how clean and sharp tip must be; lathe sharp is not good enough. If you can see any nicks under a 20x loupe, no good.
6th:
Carbide blanks are usually dull, no good. Faces must be ground and polished; inserts for Biax scrapers come mirror bright, which is why they are expensive.
7th:
My homemade scraper will accept anywhere from 3/32 thick to 1/8 thick blanks, so I can use cheap ebay carbide or the good stuff. The standard biax insert is 3/32 thick, with 3/4" x 1" being the most popular (most people seem to use the inserts dressed with the 3/4 side as the cutting edge. They are ground with 4 work edges, so don't get too frightened if you order some inserts from Dapra; you might grind that insert once if you do this for a hobby.
8th:
I use a granite straight edge for the box ways and flats because it is a whole lot cheaper to get accuracy/foot with granite. Regardless of the straight edge, always run a sharpening stone (any kind) lightly across the surface before touching with your master, even if you haven't started scraping, otherwise you risk scratching the master (like I did). A few scratches don't hurt, but they add up. Brush off the surface also beforehand.
9th:
Apply spotting fluid to the master sparingly, everybody always starts out with too much. Use a small amount and take your time spreading it out with the rubber roller. A good spot with show light color in the center, with blue around the edges, not all blue.
When I think of more screw-ups and lessons, I'll post for anybody who wants to scrape their own machines.
