It may be the grease in the bearings getting thick at low temperatures. Try warming the bearings with a hair dryer. Metal parts will contract at low temperatures. If there are differences in the metals, shrink rate may not be the same and close fitting parts may bind. Try warming the metal parts that may have problems with shrinkage. Once you find the parts that are affected by cold weather you may be able to make some adjustments to compensate.
CarveOne
CarveOne
http://www.carveonecncwoodcraft.com
