These setters like everything perfect. Voltage and current.
If you have the maintenance manual these is a trouble shooting section where test points are shown and values given.
Typically there is issue with one axis, not 3. Thus I would be checking power at T2 the large transformer in the back cabinet up top. Check (from left) the first and 4th wire. What is the voltage? Then the 2nd and 5th, etc.
The most common issue with a drive is the final drive transistors. You should have a stack of them. 2N6547. Current should be set to 8 amps at the DC fuses. Note that never hook up or disconnect a meter or pull a fuse with the drives ON. Current is set by the ACC board.
George
