Fanuc 6 DNC
The DB25 on the Fanuc 6 is typically a bi-directional serial port for loading to the "limited" memory on the control. In order to DNC (drip feed) you must use the tape reader.
For those who do not want to use a tape reader, you can purchase a BTR (behind the tape reader) which will emulate the tape reader and "trick" the CNC in drip feeding. The BTR is very small, can gain power from external power supply or tape reader port, and has DB9 serial port to connect to PC's serial port.
Put the machine in TAPE MODE and load any size program you wish with a BTR from Predator. More info or questions, give me a call.
Greg Mercurio
Shop Floor Automations, Inc.
www.shopfloorautomations.com
(619) 461-4000 Tel
