My company is about to release a complete package consisting on a machine/tools and software to produce hydraulic and pneumatic seals of any dimension up to 500mm (20 inches), in several raw materials and profiles. A seal can be produced in a matter of minutes.
This system is under tests since February 2009 with good results and the product is ready to go on a commercial basis. The user does not need to be an expert in CNC machining or does not need to write the code. Our software does it all, just input the seal dimensions, and you are ready to go.
Currently we are able to provide the following:
1) Complete machine + tools + software + raw material (starting at 28000€)
OR
2) tools + software + raw material (you will need a cnc lathe) (starting at 4600€)
Basically we are on a survey to understand if there are clients that would prefer to use they currently system (cnc lathe) and adapt it to produce seals. This could be a very low price for starting producing seals in house without a large investment. Check a video at:
[ame="http://www.youtube.com/watch?v=f-h2TDuBgE8"]YouTube- mastor_seal_production_640.avi[/ame]
or our profile range at:
http://mastor.no.sapo.pt/pt/fvedantes/fvedantes.htm
(currently, the descriptions are only in Portuguese, but profiles can be seen)
Any comment please email mastor.lda (at) gmail.com.
