587,006 active members*
3,032 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > WTB: linear bearing system for press brake
Results 1 to 2 of 2
    Jun 2005
    53
    I have been looking on various websites and have found tons of linear bearings. I need something that will work for my application. If someone has a better suggestion I am open to other options. I have access to a lathe, mill, tig welder
    Looking for shafts and the bearings for something like this:
    Dec 2004
    312
    for this application i would use bronze bearing since the accuracy doesnt have to be perfect.. cheap simple bearing..
    for press stuff i suggest you contact one company at port kells i cant remember the name for it.. its on 96 ave and 194st area
    the specialize in die for press..
    Cheers
    Dan
  1. Press Brake
    By davesnd in forum CamSoft Products
    Last Post: 12-02-2009, 07:11 AM
  2. NorthStar Press Brake For 20 Ton Shop Press anyone ever use one?
    By dsmdude in forum Bending, Forging, Extrusion...
    Last Post: 04-13-2007, 10:01 PM
  3. I need someone with a Press Brake
    By murphy625 in forum Employment Opportunity
    Last Post: 01-25-2006, 11:11 PM
  4. Best linear bearing system for a dusty router
    By ddgman2001 in forum DIY CNC Router Table Machines
    Last Post: 05-29-2004, 01:19 PM
